30-06-2009, 09:18 AM #1
wall panel supports - cold stores
Long wall panels which need to be supported from outside, there are many options & designs available. What is the cost effective & simple solution for this?
05-07-2009, 05:31 PM #2
Re: wall panel supports - cold stores
Hello smpsmp45
The outside support depend on the many factors
The hight of the walls
The type of panel ,with channels or plane
The thinkes of the panels
The cover sheet of the panel Metal or fiber
It will be located outside or inside
What is the speed velocity of the wind against the walls
Gwapa
06-07-2009, 01:11 PM #3
Well it seems you have done a lot of exercise on this. I had referred to various ways offered by companies like ISOCAB. KINGSSPAN ISOPOLI etc. But anyway
The hight of the walls 12.5 Outside / Inside clear 11.62
The type of panel ,with channels or plane - With Corrugations
The thinkes of the panels - 170mm
The cover sheet of the panel Metal or fiber - 0.6mm Precoated sheets
It will be located outside or inside Outside
What is the speed velocity of the wind against the walls No Idea. You can consider Best / Worst Scene for location in Indonesia
11-07-2009, 05:15 AM #4
Dear smpsmp45
We are making already a similar one
The worst outer wind is 80 Km/h in our zone close to the coast see . Also it is located in a zone of earthqueak 5 (you should also consider )
We are supporting the panel at 4 m and 8 m hight
We fix the panels to the outer structure (at 4 and 8 m) with an special nylon screw M10
Hope this help
Regards Gwapa
13-07-2009, 07:44 AM #5
Smpsmp, Isocab is a Belgium company situated 35 miles from me.
Are those used in you country?
I have an Isocab manual with all sort of different attachments methods in it for their panels.
Will have a look for you.
It is in Dutch and I got it from an Isocab technician which they use it on site.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
13-07-2009, 10:14 AM #6
SmpSmp
I have something but it is too big to post here.
Send me a PMIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
Fresh air in the Cold stores
By smpsmp45 in forum NH3Replies: 15Last Post: 09-05-2009, 01:20 AM -
Cold Store Panel
By snow_man in forum Trouble ShootingReplies: 2Last Post: 31-07-2008, 08:05 AM -
Support for the wall panels - cold store with no locks
By smpsmp45 in forum NH3Replies: 1Last Post: 10-07-2008, 09:06 AM -
Multiple ref. units for cold stores
By smpsmp45 in forum CommissioningReplies: 12Last Post: 21-06-2007, 06:02 PM -
lighting in cold stores
By smpsmp45 in forum ElectricalReplies: 0Last Post: 29-05-2007, 01:57 PM
