Thread: Draining Oil Pots.
29-06-2009, 04:44 AM #1
Draining Oil Pots.
When I drained oil pots today I noticed there was quite alot of difference between the colour of the oil coming out of each. For example one was really white and fluffy while another was the opposite really dark and thick. Why is there such a difference in the oil colour coming out and what causes it.
Thanks for your replys in advance.
Chris.
29-06-2009, 03:05 PM #2
Re: Draining Oil Pots.
Did one stink more than the other?
You may have had more ammonia in the one with the foam. Did the foam disappear after a while and look like a regular oil drain sample?If all else fails, ask for help.
29-06-2009, 07:03 PM #3
29-06-2009, 07:55 PM #4
Are you draining from different temperature systems ?
Like - 10 deg C & - 30 deg C
29-06-2009, 09:47 PM #5
no its 4 large screw packages all with the same evap temp. yeah that would make sense with ammonia still in the oil. thanks very much.
