Thread: Duct Fittings Loss Coefficients
28-06-2009, 08:08 AM #1
hai Friends
I want to know about Duct Fittings Loss Coefficients. Normaly i am collecting all data from ASHARE hand book but i need one easy formula any body can help this problem???????
28-06-2009, 08:15 AM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: Duct Fittings Loss Coefficients
I also want many, many things.
Most of them I got when I say "please".
28-06-2009, 09:04 AM #3
hallo friends
Actully i dont know more things about SP Calculation But i Made One Exel Sheet For SP Calculation. any way i will upload that exel sheet please try and tell me commands. In Straight Duct Pr. loss You Can Calculate from Air flow (cfm),Duct size(width" & height") & Duct Length. , And another section for duct fittings (Elbow,Transition, grills, diffusers, branches,Tee .etc. .....) you must put cfm,sizes and loss coefficients ( loss coefficients you calculate from ASHARE Hand book) Please Try AND tell Me the Commends
28-06-2009, 09:48 AM #4
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
I am not aware of any formula which will give you fitting pressure loss.
You must fill your Excel sheet with all equivalent lengths for all possible fittings and then choose between them when calculating.
Or you could use specialized software like Autodesk Revit MEP which makes all calculations while you are drawing ducts.
28-06-2009, 10:07 AM #5
thanks nike!!!!, i have that equivalent length methods. but somebody talled me more accurate calculation is this one that means i am serching loss coeiff. formulas
28-06-2009, 10:11 AM #6
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
28-06-2009, 10:30 AM #7
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
28-06-2009, 10:44 AM #8
hi nike123
i check this site this is useful for me
thanks
29-06-2009, 06:59 AM #9
hallo friends,
i have 1997 ASHARE Hand Book Duct Design(Chapter 32) any Body WANTS that Please sENd PM
Duct Size Calculations
By hamidpia in forum Tools and CalculatorsReplies: 17Last Post: 21-06-2010, 01:56 PM -
Duct Fitting Loss
By harsen in forum FundamentalsReplies: 6Last Post: 01-06-2009, 11:10 PM -
Oil Loss 250 VLD Mycom Screw
By Keith1977 in forum NH3Replies: 23Last Post: 20-09-2008, 12:28 PM -
Duct Sizing!
By C_Henderson in forum Air ConditioningReplies: 3Last Post: 02-03-2008, 08:14 PM
