    mikseidis's Avatar
    mikseidis Guest
    screw compressor CSH 75
    Hello
    I have a little problem with this compressor.
    the controler shows high discharge temperature.
    What can be possible failures
    Nov 2004
    China
    176
    Re: screw compressor CSH 75
    What are the operating conditions? what is the refrigerant?
    70
    4,700
    47
    Hi Mikseidis.
    There could be many reasons for your High pressure Fault.
    If the tranducer is reading correctly.
    The speed at which you observe the HP rise from start-up would be a good indicator.
    Also is this a stand alone system or 1 of several. etc.
    In no particular order
    lack of HP cooling, Cond. water / air?
    overcharged? (unlikely unless you have adjusted the charge).
    Air in the system?
    chocked liquid strainer?
    Condenser scaled or dirty?
    Moisture in the system?
    Faulty Expansion Valve (closed)?
    For example!
    Cheers Grizzly.
    For a better answer give us more info!
    Mar 2010
    Dammam
    83
    What AC/Refrigeration system you are using?,also the refrigerant?..,more info pls..
    <"No one is so smart, they just stay with problems longer and use their imagination">
  1. VSD on screw machines
    By Mike Hopkins in forum New Technologies
    Last Post: 20-02-2011, 12:10 AM
  2. R22 - R417 (RetroFit) Screw set A.C
    By Chris_Atlantic in forum Trouble Shooting
    Last Post: 23-04-2010, 06:53 PM
  3. Compressors - screw or reciprocating?
    By Josip in forum Industrial Compressors
    Last Post: 27-01-2009, 10:36 PM
  4. Replies: 7
    Last Post: 23-09-2008, 09:24 AM
  5. Mono or twin screw
    By Nirmalya in forum Industrial Compressors
    Last Post: 12-09-2006, 03:19 AM
