    Oct 2007
    jersey channel islands
    186
    410a high pressure data logger
    hi, everybody does anyone know where i can buy a pressure logger for 410a systems .
    had a problem the other day with a unit showing hp fault
    and cutting out but would restart after resetting remote.
    this was happening at night as we had been there in the day with gauges on it , and it didnt do it , but come the morning it had stopped.
    this was traced to a duff pcb after a lot of time, and its running fine.
    if i could get a data logger to leave on the true high side i could of seen the trend , our logger at the moment only rated to 32bar i think.
    and require 45bar
    any ideas?
    11,025
    Re: 410a high pressure data logger
    Oct 2007
    186
    yes thats thing, many thanks for your time.
    just need to get the boss to buy it.
    Feb 2005
    Australia
    123
    21
    If you already have a datalogger that can handle a 0-5VDC or 0-12VDC signal try and get hold of a pressure transducer out of a VRV/VRF unit. Most of them these days monitor HP and LP and their pressure transducers just feed a signal back to the controller pcb. They are available as spare parts and the tech info should be around to work out what voltage output equates to what pressure.
  1. 9 superheat & subcooling scenarios
    By nike123 in forum Fundamentals
    Last Post: 19-07-2011, 03:16 AM
  2. high liquid line pressure?
    By TECH TIM in forum Commercial
    Last Post: 09-05-2009, 05:36 PM
  3. High Pressure Freezing
    By mattynige in forum New Technologies
    Last Post: 19-06-2008, 02:03 PM
  4. Too high external static pressure
    By racknovice in forum Air Conditioning
    Last Post: 26-08-2007, 09:20 AM
  5. High pressure fan
    By snow_man in forum Trouble Shooting
    Last Post: 27-04-2007, 01:52 PM
