25-06-2009, 06:09 PM #1
compressor run 4 mins then off 7 mins
Hi there, i need your help
i'm working on refrigerator using r12 it's very old, the compressor using 3 in 1 relay, start capacitor and was run for for 3 mins then off for 7 mins and on for 3 mins again and again, But, both side fan is still runing only the compressor off and on, i checked superheat i got 36F and subcooled i got 31F and i also checked temp control it's working ok and nothing block the eaporator coil and the condenser coil, the onwer said he did replace the compressor 2 years ago...you think it's has restriction on the cap tube? or it's just low charge? but if low charge subcooled should be low right? or maybe 3 in 1 is bad? thank you vrey much for your help..
25-06-2009, 08:44 PM #2
Re: compressor run 4 mins then off 7 mins
what cind of compressor are we talking about ??? hermetic, semi-hermetic??? what regulates the cycle of the unit ??? is there not a start and stop timer,and if so,how are they regulated ??? is the compressor running hot and shut of on the temp safety device ?? if you want to now if it is low or high on refrig we need some pressure readings. also if the plant is used for cooling or freezing and what temperature is desired.
O yes, welcome on this forum.
Ice
25-06-2009, 09:01 PM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
26-06-2009, 02:38 AM #4
it could be the relay or the compressors stuffed,but meter compressor windings to make sure they total ok,check current draw to see if its in excess of overload rating as this is what sounds like is happening and compare it to locked rotor amps.their is an equation to determine locked rotor amps by percentage value anybody out their who can help out with this ?
Compressor run for 3 mins then off for 10 mins
By sanya in forum Trouble ShootingReplies: 7Last Post: 20-06-2009, 01:25 PM
