Results 1 to 2 of 2
    Manoj.T.M's Avatar
    Manoj.T.M Guest
    Unhappy Tonnage calculation
    Hi All, i have struck up with some queries!!!
    can anybody help me out for calculating the TR of an unit, by taking superheat and subcooling temperature...is there any formula for it or is there any calculator for this
    And as we are using R410a refrigerant for the first time, i also would like to know the superheat and subcooling range of temperature for it, and its Low pressure(LP) and high pressure(HP) recommended.
    Apr 2009
    israel
    778
    Re: Tonnage calculation
    hi if u are trying tu calculate how much tonnage u are getting out of your unit this is the correct and easy calculation
    delta t *1.8 *500*GPM divided by 12000= TR
  1. Need Help in Refrigeration Calculation
    By Jason_09 in forum Fundamentals
    Last Post: 30-06-2009, 07:10 PM
  2. Calculating Tonnage of refrigeration machine
    By batmon18 in forum Commercial
    Last Post: 09-06-2009, 11:21 PM
  3. Flash gas calculation software
    By nike123 in forum Tools and Calculators
    Last Post: 12-03-2009, 09:25 AM
  4. Replies: 3
    Last Post: 27-11-2007, 10:00 AM
  5. Cooling load calculation
    By raviperumal in forum Technical Discussions
    Last Post: 02-03-2007, 04:09 AM
