Results 1 to 10 of 10
Thread: vulcan lokring
    May 2009
    uk
    44
    vulcan lokring
    hi i ve been toying with the idea of getting a vulcan lokring pipe jointing system has anbody got any views on these positive or negative and how does it perform with R410A
    thanks nick
    Re: vulcan lokring
    Hi Nick, this has been discussed before...
    Start here for a quick read up-
    http://www.refrigeration-engineer.co...hlight=lokring
    Also do a search on the forum for 'lokring' and you will find some more.
    5,667
    Re: vulcan lokring
    We took the plunge and purchased a Lokring set a while ago - selection of fittings and the tool, plus different size jaws and now have a few joints made on different sites.
    So far, so good.
    We only tend to use the system when other methods would be time consuming,(PITA) i.e. getting a hot work permit that may take a few hours to organise, dragging brazing kit all the way to the roof, or something similar.
    I must say though, that with each joint we make, our confidence in the system grows. So far, no leaks.
    May 2009
    uk
    44
    Re: vulcan lokring
    thanks for the info think i may get one im fed up waiting around for hwp's
    michael 030654's Avatar
    michael 030654 Guest
    Re: vulcan lokring
    Guys - Lokring has been used by the refrig industry for more than 30 years. You can use it with confidence. the advantages are numerous.
    Last year the product was approved by TUV for use with R410a.
    Re: vulcan lokring
    VULKAN LOKRING has been universally used by the refrig industry for more than 30 years - you can use it witrh confidence. The advantages are numerous and become apparant when you begin to use it.
    Last year the product range became TUV approved for use with R410a systems.
    5,667
    Re: vulcan lokring
    Which one do you want me to delete Michael?
    The first one or the second one
    May 2009
    uk
    44
    Re: vulcan lokring
    thanks for the advice guys just looking around for a good price on a lokring kit
    Jul 2007
    43
    Re: vulcan lokring
    Well, have taken the plunge and bought a Lokring kit. Used it today on a 410a split, pressure testing tomorrow so will see how it goes!
    Aug 2009
    South Africa
    29
    Re: vulcan lokring
    Nick
    Get hold of Lokring for technical advice but I can tell you they state a failure rate of 2 parts / million if installed correctly with the right bonding liquid. It is a bit more expensive than welding and there is the cure time factor (a negative). Tools are not cheap (another negative).
  1. Lokring... anyone use it regularly?
    By trial in forum Fundamentals
    Last Post: 22-05-2008, 10:48 PM
  2. Vulcan Lokring group buy!!
    By Daikin=Overated in forum Air Conditioning
    Last Post: 22-05-2008, 12:09 PM
