Results 1 to 10 of 10
Thread: compressor oil
23-06-2009, 10:07 PM #1
compressor oil
hi im changing the gas on a r22 freezer to r404a.Change expantion valve etc.Also i will drop the old oil out and replace with right oil for 404.my quetion is,will threre still be oil in oil sep,or will just changing the oil do?Thanks
24-06-2009, 12:35 PM #2
Re: compressor oil
Drain the separator & pre-charge ester oil as marked on oil separator. Besides, while system operates with ester oil ,change the oil one more time . This would remove left over mineral oil .
05-07-2009, 12:42 PM #3
Re: compressor oil
Hi guys, Im new to this site,and it looks like there's a wealth of information here. I have a question concerning a walk-in cooler, useing 407,what is the pressure for a 40 degree space temp unable to find press/temp chart. Thanks
05-07-2009, 03:55 PM #4
05-07-2009, 05:22 PM #5
Re: compressor oil
Hi Dunny.
read the attached regarding oil and refrigerant changes.
As specified by Copeland.
More experienced retrofit guys may be able to advise more.
11-12-2009, 02:22 AM #6
Re: compressor oil
Hi there! I am replacing my old copeland compressor model KALB-015E with KALB-015L. They have the same power supply. What would be the differenc if the other one is "Less Oil" (code L)? Should I add oil to it? Thanks!
11-12-2009, 11:51 AM #7
Re: compressor oil
Just verify the Specs of both the models. I think the oil qty. Of both the models are same.
14-12-2009, 01:48 AM #8
14-12-2009, 05:51 AM #9
Re: compressor oil
Here ya go
http://arkemaus.com/pdf/fluorochem/F..._pres_temp.pdf
normMy wife used to say you never listen to a word I say at least I think that what she said
26-04-2010, 09:20 AM #10
Re: compressor oil
it's always better to clean the whole circuit and remove 100% of MO, so you can gon to the refrigerant you want.
check this video:
http://www.fri3oilsystem.com/ingles/video/video.html
