Results 1 to 8 of 8
23-06-2009, 07:26 AM #1
How to calculate atmospheric dewpoint of compressed air?
Ambient air at 35 degree C is compressed to 3.5 bar(g). It is cooled to 12 Deg C by passing throug a heat exchanger using chilled water at 8 degree C. How to calculate the atmosphric dewpoint of this compressed air at outlet of heat exchanger?
23-06-2009, 02:21 PM #2
Re: How to calculate atmospheric dewpoint of compressed air?
I am going to ASSUME ALL CONDENSER WATER AVAILABLE. and Use this
.engineeringtoolbox.com/water-content-compressed-air-d_1275.html[/url]
air out 100% HR
and this to calculate load of air.
.engineeringtoolbox.com/air-temperature-pressure-density-d_771.html[/url]
Sorry mi english
25-06-2009, 04:08 PM #3
I think you will need the Ph chart for compressed air where you can get all air properties like , pressure, enterpy, entropy, DbT,WbT, and dew points
27-06-2009, 04:48 AM #4
for starters, you will need to know the mositure content of the 35C air that is getting drawn into the compressor
odds are if you are anywhere humid, at 12C the air will be saturatedTake the V out of HVAC and you are left with a HAC job
12-08-2009, 10:38 AM #5
Dear Members I am new one I want to know about the certificate of safe handling I want to get addmission in UK I am in Pakistan working in a HVAC Firm
09-09-2009, 04:43 AM #6
Dear members i am a new user,can you help me out in using refrigerants,that is which gas can be used in place of the other, like R134a gas can be used in R404a if i am not mistaken?
13-09-2009, 05:36 PM #7
the dewpoint will be close to 8 degrees as this is your water temp , however when changing the pressure it will be lowered.
obviously when pressure is 2 bars the water content is same but the RH will be twice of outside.
When pressure is higher some water will condense and in your cooler a lot of water will condense, when after cooler you use a pressure controller it will be good.
i use starting air of 25 bar for instrument air.computer shooter
paul deelen
+31653300739
14-09-2009, 10:12 AM #8
Hi have a look at this.
http://www.mellcon.com/compressed-air-dewpoint.html
NormMy wife used to say you never listen to a word I say at least I think that what she said
To Calculate Heating Load of an air compressor
By mistershark in forum Air ConditioningReplies: 28Last Post: 16-06-2009, 06:36 PM -
Atmospheric Condenser Sizing/Calculations (Simplified)
By Ivan Lim in forum Technical DiscussionsReplies: 0Last Post: 27-05-2008, 03:37 AM -
Formula to Calculate
By suny in forum FundamentalsReplies: 7Last Post: 09-08-2007, 02:38 AM -
Help to calculate Heat Exchancger
By Carode in forum FundamentalsReplies: 1Last Post: 17-12-2003, 10:57 PM
