Results 1 to 12 of 12
Thread: cps vacuum gauge
22-06-2009, 11:32 AM #1
cps vacuum gauge
hello, i have a cps vg200 digital vacuum gauge and the readings are up the creek, it will only read properly if not connected to system. once the system is in a vacuum it just takes a lon time to register what micron it is reading. has anyone else seen or heard of this. thanks CT
22-06-2009, 12:31 PM #2
Re: cps vacuum gauge
Have you tried washing the sensor in alcohol or similar. May be oil contaminated.
22-06-2009, 11:39 PM #3
Are you sure that the vacuum you have created is low enough to register on the gauge?
Also, as stated above, make sure that the sensor is clean and the battery is good.Brian - Newton Abbot, Devon, UK
24-06-2009, 08:57 AM #4
hey guys
cleaned out with metho pulled vac pump down to 250 microns with dirty vac oil in pump.
thanks for your help guys
25-06-2009, 08:18 AM #5
Hi, guys
Can anyone tell where I can buy pressure gauges, vacuum pump, recovery unit,..etc.. but not too expensive for a tight budget and somewhere here in London.
25-06-2009, 08:58 AM #6
local refrigeration dealer, i paid $330 aud for the vac gauge, $460 for a 120l/min vac pump. recovery unit about $900 aud. which is pretty good price for all
30-06-2009, 12:53 PM #7
30-06-2009, 01:37 PM #8
Ah ha, another G.C-er! Welcome to R-E chillifive.
Sidi, I'd try fleabay. However remember you get what you pay for!
01-07-2009, 08:05 PM #9
in Belgium we have a saying " goedkoop is niet altijd goeiekoop"...so translated it sounds " cheap bying isn't always best bying"
Ice
01-07-2009, 08:17 PM #10
Had the same problem myself, connected up the vac pump and stared pulling a vac, next the gauge stops working. Vac pump had pulled out oil mist from the system and contaminated the sensor. Now i vac systems for an hour befor fitting the guage, no more failures.
ice/ruuner
01-07-2009, 10:47 PM #11
^ Also, vac guage shouldn't be fitted to vac pump; it should be connected directly to the system if possible.
03-07-2009, 01:18 AM #12
And also as far on the system from the vac pump connection as you can get.
Sticky Imperial hp pressure gauge
By desA in forum Trouble ShootingReplies: 12Last Post: 21-04-2009, 03:03 PM -
Troubleshooting a vacuum pump and gauge set.
By Old Codger in forum FundamentalsReplies: 7Last Post: 08-08-2008, 05:13 PM -
Evacuation Procedure Electronic Vacuum Gauge
By Refrigerologist in forum CommissioningReplies: 30Last Post: 14-04-2008, 12:34 AM -
inverters pulling vacuum
By bangoman in forum Air ConditioningReplies: 2Last Post: 05-02-2008, 09:12 PM -
Vacuum test
By Peter_1 in forum FundamentalsReplies: 15Last Post: 13-10-2006, 09:04 PM
