Results 1 to 1 of 1
22-06-2009, 05:30 AM #1
Make Split A/C with refrigerator system
I want to asked, could I make the split A/C with compressor refrigerator?
evaporator refrigerator was soaked by me in the basin contained water, then water that already cold was channelled by me to A/C evaporator used the pump aquarium?Last edited by James priyono; 22-06-2009 at 09:47 AM.
3 single split units or one multi split - consumer advice needed
By kok in forum Air ConditioningReplies: 18Last Post: 15-04-2009, 08:42 PM -
Sensible Heat Factor / capacity of Inverter split Systems at part load?
By Greengrocer in forum Technical SpeculationsReplies: 31Last Post: 09-02-2009, 04:57 PM -
Heating not working on split system what is the problem?
By airflo in forum Air ConditioningReplies: 10Last Post: 22-07-2008, 06:42 PM -
Do you beleive in data of split units?
By jirhol in forum FundamentalsReplies: 4Last Post: 29-03-2008, 11:17 PM -
High overcurrent on 3.5kW heatpump split
By Makeit go Right in forum Air ConditioningReplies: 12Last Post: 08-03-2007, 12:27 AM
