Results 1 to 10 of 10
    May 2009
    uk
    44
    1930 s cellar cooler
    A few years ago i was installing AC in a pub i arrived the day after the builders labourer had cut through a 2 inch diameter shaft with an angle grinder releasing an unidentified gas the building and surounding areas were evacuated an the fire brigade were callled out
    the shaft had a tangential fan mounted on each end and was belt driven one end was cellar air the other was outside air i belive it was a centrifugal form of refrigeration made sometime in the 1930s just wondered if anyone could shed some light on it thanks nick
    May 2008
    66
    802
    Re: 1930 s cellar cooler
    so where was the gas comming from ???
    you just discribed a form of ventilation system that runs during the night,an cool dawn the space via shafts, a kind of motorised free cooling system. now a days the do the same but whit tube's 25 mtr down under,to create the same cooling or pre-heating effect,the temperatuur is nearly always the same at a dept of min. 25 mtr,around 10C°.
    Ice
    May 2009
    uk
    44
    my description was not very good it was basically a condensor and evaporator mounted on a spinning shaft i belive the compression was created by centrifugal force ie the condensor and evaporator spun i hope this gives a cleare picture thanks nick
    May 2008
    66
    802
    so this is one of the urley NH³ installs, whitch also functions like an absorbtion system???
    Ice
    May 2009
    uk
    44
    i dont think it was an absorbtion system it was a rotating condensor and evaporator i think centrifugal force created compression there where no rotating seals it was all self contained on the one shaft
    Feb 2008
    adelaide sth.oz
    1,015
    remember seeing something like that at trade school,two balls spinning,creating pressure drop,one got cold the other warmed up,i think was one of the first refrigeration practises.might have a look at wikepedia later on
    Auckland
    74
    3,357
    38
    sounds like a methyol chloride or else a sulphur dioxide system, do not know about spinning balls, but sounds painfull.[ hell could be a goveror on a weird what ever extract system ]
    If smelly NH3 or sulphur dioxide, non smelly but leathal possibly methyol chloride. Could always be just a weird type exhaust fan as cellars were at ambient.
    Who would ever know. magoo
    May 2009
    uk
    44
    it was definately a refrigeration system with a nasty refrigerant i gather quite a large area was evacuated
    Mar 2009
    U.S.A.
    320
    May 2009
    uk
    44
    perfect match Sterl it was identical to your link thanks very much been bugging me for a while as to what it was
  1. NRS BeerMaster cellar cooler
    By madfriday in forum Commercial
    Last Post: 22-06-2009, 09:24 PM
  2. Cellar Cooler Icing Problems
    By Baz in forum Trouble Shooting
    Last Post: 31-03-2009, 09:27 PM
  3. Hubbard cellar cooler
    By birchy in forum Commercial
    Last Post: 06-05-2008, 11:46 PM
  4. cellar cooler fault.
    By fireblade in forum Commercial
    Last Post: 11-07-2007, 11:33 AM
  5. Searle cellar cooler control problem
    By iceman007 in forum Electrical
    Last Post: 06-07-2004, 08:57 PM
