    barryd's Avatar
    barryd Guest
    Cooling down my Pc's existing water cooling.
    Good day every one.
    To begin wiht I am a complete noob when it comes to cooling things down so please forgive me lack of techinicall knowledge and terms.
    I have a water cooling unit for my pc and was thinking of cooling the water down even further. I was thinking of going to a second hand shop and buying and old but still working water cooler with a compressor and heat exchanger or an old refrigerator and somehow adapting the compressor to cool down the water to around 5deg celcius.
    Is this at all possible and can someone please give me a few pointers on how to do this.
    Regards.
    Barry Bolton
    Sep 2005
    42
    191
    Re: Cooling down my Pc's existing water cooling.
    you'd be better off using a peltier element with a 2nd water loop....
    you'd need more cooling than a watercooler/small fridge could provide.... so would need a custom system building...
    if you want to go to sub ambient temps, you'll be better off with say 2 x 500w peltier elements cooled by a 2nd water loop... controling the 2 elements on/off to mainitain temprerute....
    what is your water temp like now ?
    I'm at 30'C (water temp)
    core2duo @ 4.40Ghz and 35'C
    ATI 4870 @ stock and 36'C
    north bridge is at 45'C
    hard drives (w/c also) at 33'C
    and a watercooled PSU
    I can drip temps quite a bit if I run the fans/pump on 12v... but i like nice quiet 5v fans and 7v pump
    northbridge is a little warm... the waterblock is fixed onto the heatpipe system thingie...
  1. Water cooling condensers
    By FEISTY in forum Trouble Shooting
    Last Post: 28-03-2009, 01:48 AM
  2. pure water from air
    Last Post: 26-02-2009, 12:25 PM
  3. Modifying aricond. for heating, cooling and hot water
    By kimusabi in forum Technical Discussions
    Last Post: 10-10-2008, 07:28 AM
  4. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Industrial
    Last Post: 14-10-2005, 06:34 PM
  5. Building a wine cabinet
    By Rory in forum Technical Discussions
    Last Post: 13-07-2004, 08:28 PM
