Results 1 to 8 of 8
20-06-2009, 04:26 PM #1
R407 inside unit on old R22 compressor ?
hello
I have an old Daikin 3 way multisplit with R22 at my house. There is only 1 (out of the possible 3) inside units connected and I want to add an extra unit. Can I add a newer inside unit that has been used with R407 ?.
20-06-2009, 04:40 PM #2
Re: R407 inside unit on old R22 compressor ?
The electronics on the newer unit might not be compatible.
Andy
21-06-2009, 06:05 AM #3
Electrics are ok - interface is a single wire to switch the outside unit on or off by a relay (240v=on 0V=off)
So there is no issue with the diffferent fluids then ?.
21-06-2009, 09:20 AM #4
hello, you could flush out the coil, new copelands. most new compressors come out with poe oil and R22 will still run if there is a little bit of poe and mineral oil.
someone who knows a bit more will be spot on.
21-06-2009, 04:26 PM #5
if it is a new unit,never being used,and the system is on/off,then there is no problem and it will work just fine. just don't expect that the R407 unit have the same quality as the R22 unit. if it is a used one,R407C,clean fermly the inner tubing,because the POE (polyester ether) oil will damage the mineral oil based compressor.
good luck, Ice
21-06-2009, 08:28 PM #6
The indoor unit is an Airwell that is sold for R22 and R497 use. The actual unit I plan to use has been previously used with R22 - but I plan to add two more units (so I 'll try to get these new).
Many thanks for the advice.
21-06-2009, 09:00 PM #7
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
24-06-2009, 07:08 PM #8
so the outdoor unit is a Daikin and now there is an Airwell indoor on. or you are going to hang an Airwell unit on a Daikin ??
a bit confusing no ?? i don't think you can mount an Airwell indoor on a Daikin outdoor unit,ore the electricals has being fermly changed and work like an on/of system. even do, good luck.
Ice
[Autocascade] Only a project ATM
By before in forum CPU OverclockersReplies: 1Last Post: 07-05-2009, 11:13 AM -
How to Design Refrigeration Systems
By US Iceman in forum FundamentalsReplies: 63Last Post: 24-07-2008, 04:27 PM -
Change over 2 outdoor unit
By bach in forum Air ConditioningReplies: 8Last Post: 08-06-2008, 06:55 PM -
Heater/cooler split system A/C electrical connections help pls!
By JamesQB in forum Air ConditioningReplies: 5Last Post: 22-06-2005, 07:41 PM -
Compressor failure...... cause
By herefishy in forum Technical SpeculationsReplies: 8Last Post: 06-12-2002, 12:15 AM
