    Mar 2006
    Lancashire
    1,859
    28
    Lennox unit head pressure control
    Last year i posted about a lennox unit we had inherited on a maintenance contract.
    KVHK48.DVFC
    http://www.refrigeration-engineer.co...ghlight=lennox
    Since that post we have had so many problems with it it's untrue.
    I got called to it the other day and circuit 2 was tripping on HP ( which is controlled by dampers ).
    I checked the dampers and they were closed when the pressure was 24 bar. The dampers aren't seized and the actuator does move.
    I can't find a service manual anywhere for this model and i tried to contact lennox but got no answer.
    Does anyone know the range the dampers are supposed to work between?
    Also what controlls it? I noticed a pressure transducer on circuit 1 but nothing on circuit 2.
    There is only 1 actuator that controlls the dampers for both circuit 1 and 2.
    Marc
    Somerset
    69
    4,697
    Re: Lennox unit head pressure control
    Hi Marc
    Logically they would be pressure controlled, obviously what refrigerant you are running on.
    Would have huge bearing upon what your head pressure control of the dampers would be!
    Like you I cannot find reference to this unit on the Lennox website.
    What do you think?
    Mar 2006
    Lancashire
    1,859
    28
    I managed to find a manual but it isn't much help, the unit is on r407c.
    http://www.lennoxeurope.com/transfer..._KVHK-0404.pdf
    It doesn't say much about the Condensing pressure control only on page 20
    "Based on 2 dampers on the outdoor unit discharge air, which lets you control condensation temperature through air flow
    The damper is moving by a servomotor, which receives a proportional signal throughnanpressure detector".
    One thing that i noticed is that on page 9 it says minimum on coil temp of the indoor unit is +15C on cooling but the indoor is in the carpark outside and the air is ducted upstairs.
    Marc
    11,025
    Haven't found a manual yet but found some spec details if you want...
    http://pdf.directindustry.com/pdf/le...29175-_34.html
    Bottom of page 34/192
    edit:
    There you go, one Manual..
    Mar 2006
    Lancashire
    1,859
    28
    Thanks for that Brian.
    The manual doesn't show anything about the head pressure control- what a surprise.
    Marc
    11,025
    Just says that it is a electric servo motor run off pressure transducers. As you have already said, sorry must read deeper into your posts. DOH!
  1. Alco/Emerson head master/condensor pressure control
    By liptow in forum Fundamentals
    Last Post: 13-05-2009, 01:50 PM
  2. Lennox Unit problem
    By marc5180 in forum Air Conditioning
    Last Post: 13-12-2007, 09:20 PM
  3. Control scenario
    By Mike Hopkins in forum Technical Discussions
    Last Post: 14-09-2007, 11:25 AM
  4. High head pressure no duty
    By LRAC in forum Commercial
    Last Post: 23-07-2007, 12:12 AM
