Thread: Mitsubishi FDC2501HKXRE2
19-06-2009, 01:28 PM #1
Need some advice please. Recently went to a vrv mitsi unit. had blown the inverter board.
Mitsi no longer make the parts so we sent the board back to be fixed. Fitted it today and disconnected the comperessor to dry run. Bang goes the board.
Mitsi arnt being very helpful in the matter and i am more used to and keyed up for daikin units.
Mitsi say this is the only way of testing it, but as they no langer make the spare parts, looks like it mite be a rip out job.
Has any one ever experienced this???
Cheers, steve
19-06-2009, 07:30 PM #2
Re: Mitsubishi FDC2501HKXRE2
When did the board blow? Was it as soon as power was turned on or as soon as the compressor started up?
Did you check the compressor was ok and not down to earth?
I went to a system a few weeks back that kept blowing the board, i found that the other company that had replaced the compressor and inverter board had connected the compressor wrong on the inverter board.The difference between genius and stupidity is that genius has its limits.
Marc
25-06-2009, 07:59 AM #3
30-06-2009, 10:49 PM #4
This is an early model of inverter system so treat it gently.
The inverter pcb is generally still available but the chips arn't so they need moving to the new board.
I would suspect the problem is with the power transducer module which feeds the compressor and is controlled by the inverter.
Brit
Few question about Mitsubishi Heavy Industrial air condition
By fireduck in forum Air ConditioningReplies: 55Last Post: 12-05-2009, 02:35 PM -
[Ask] Mitsubishi rotary compressor
By felixfab_93 in forum Refrigeration BooksReplies: 1Last Post: 18-12-2008, 10:48 AM -
Mitsubishi inverter problem
By R1976 in forum Air ConditioningReplies: 3Last Post: 16-06-2008, 09:54 PM -
Mitsubishi Light Truck Refrigeration
By Mastercool in forum TransportReplies: 2Last Post: 23-11-2007, 06:15 AM -
Mitsubishi compressor lock
By marc5180 in forum Air ConditioningReplies: 29Last Post: 08-10-2007, 05:48 PM
