19-06-2009, 10:24 AM #1
Thermal Conductivity SPCEN-IF Cold Rolled Steel
What is the thermal conductivity in W/mK of the following sheet metal at 45 deg C temperature.
Cold Rolled Steel SPCEN - IF
%C 0.06
%Mn 0.035
%S 0.025
%P 0.025
Rest is Fe
Standard : EN10130 - FeP05
I Googled and also checked Design Books. Only Mechanical Properties are available everywhere. Thermal conductivity is not available.
Kindly help me giveing the values or reference if any.
19-06-2009, 04:24 PM #2
Re: Thermal Conductivity SPCEN-IF Cold Rolled Steel
whats a W/mK not being smart just curious ?
20-06-2009, 12:13 AM #3
Its about 60 W/mK, if I remember. But this value is for carbon steel, of course it can have small variations depending of the alloy elements and the thermal treatment. If its a stainless steel with nickel and cromium it will down that value so much as much the concentration of these elements.
I hope it could helpTo make progress is never good enough, I want to do better and better and better
20-06-2009, 10:46 AM #4
Thanks. I have two values as a result of Google search.
One 51.9 W/m K (for Low Carbon Cold Rolled Steel)
The other one 93.0 W/m K ( for Low Carbon Steel - IF Grade)
Thats why i wanted to clarify. But the values are too dispersed.
Anyhow thanks for that. I will go with 51.9
20-06-2009, 10:49 AM #5
W/mK Watts per metre Kelvin
W/m °C Watts per metre degree Celcius
Btu/ft-h-F
22-06-2009, 07:31 AM #6
cheers mate thought that was the direction
