    Nov 2008
    Indonesia
    27
    Talking The so thin evaporator pipe
    Why the split A/C output now the pipe evaporator is so thin?
    So that the process of the fast refrigeration is implemented?
    Aug 2007
    Sydney
    52
    1,083
    Re: The so thin evaporator pipe
    Hi James
    You're looking young these days. Yes the thinner the copper tube is the faster heat will transfer, and smaller diameter means you can fit more tubes increasing the surface area which also increases heat transfer. But there are limmits. I digres here, the coke can measures about 1/2 diameter to 1 length this ratio gives maximum volume for minimum surface area for a cylender, all to save on material.
    Nov 2008
    Indonesia
    27
    Not with the thin evaporator will make the evaporator become fast leaked?
    Because when the split A/C did not operate will dismiss the high pressure and that made the evaporator become fast leaked.
  1. Replies: 39
    Last Post: 04-09-2009, 12:16 AM
  2. Freezing thin pipe on new a/c unit.
    By mousey1986 in forum Trouble Shooting
    Last Post: 29-07-2008, 12:29 AM
  3. the thin line
    By Tycho in forum Chit Chat & Service Stories
    Last Post: 18-06-2006, 10:27 AM
