Thread: The so thin evaporator pipe
18-06-2009, 12:58 PM #1
Why the split A/C output now the pipe evaporator is so thin?
So that the process of the fast refrigeration is implemented?
19-06-2009, 01:15 AM #2
Re: The so thin evaporator pipe
Hi James
You're looking young these days. Yes the thinner the copper tube is the faster heat will transfer, and smaller diameter means you can fit more tubes increasing the surface area which also increases heat transfer. But there are limmits. I digres here, the coke can measures about 1/2 diameter to 1 length this ratio gives maximum volume for minimum surface area for a cylender, all to save on material.
19-06-2009, 02:08 AM #3
Not with the thin evaporator will make the evaporator become fast leaked?
Because when the split A/C did not operate will dismiss the high pressure and that made the evaporator become fast leaked.
Advice on soldering/brazing thin heat fins to copper tube?
By Tom G in forum FundamentalsReplies: 39Last Post: 04-09-2009, 12:16 AM -
Freezing thin pipe on new a/c unit.
By mousey1986 in forum Trouble ShootingReplies: 19Last Post: 29-07-2008, 12:29 AM -
the thin line
By Tycho in forum Chit Chat & Service StoriesReplies: 1Last Post: 18-06-2006, 10:27 AM
