Results 1 to 8 of 8
    Jason_09's Avatar
    Jason_09 Guest
    Need Help in Refrigeration Calculation
    Hi all experts,
    I am doing some research on District Cooling System, I have difficulties on some calculation matters below:
    1. Is 1kWr=0.284 RT correct?
    2. Is 1 MJ= 0.079 RT hour correct?
    3. Is 1 kWr = 1 kW electrical? I suppose is the same
    4. say an office tower consumes 10,000RT, does it mean it consumes approx. 35MW of electricity?if this understanding is correct, it operates for 10hours it uses 350MWh?
    5. The above calculation seems to miss out the efficiency of equipment to calculate the electricity consumes for RT, is there anything missing...?
    Many thanks,
    Jason
    May 2008
    66
    802
    Re: Need Help in Refrigeration Calculation
    Quote Originally Posted by Jason_09 View Post
    Hi all experts,
    Many thanks,
    Jason
    on what ratio is the calculation based ? a cooling load of 24Hrs ??? a COP of ....??
    what are you using for cooling, refrig?? water?? brine??
    are the 10000RT day-ore night consumptions??? ore both??
    i think you have to be a bit more specific M8 if you want help on yore project.
    Ice
    Aug 2007
    Sydney
    52
    1,083
    23
    Hi Jason09
    District coolin? 1, yes. 2, yes. 3, no. 4, no. 5, yes. You need system COP to calculate kWrefrigeratoin to kW electical. Or you could just measure it, and analyse power bill.
    Oct 2003
    5,630
    34
    Hi all experts,
    Many thanks,
    Jason
    IN the 1st place, what is kWr and RT?
    Aug 2008
    Baltics
    786
    Probably, kW refrigerating and http://en.wikipedia.org/wiki/RT_(energy)
    May 2008
    66
    802
    hey peter, i was thinking kwr - kilowatt /Hrs , and RT- refrig ton.
    just guessing, Ice
    Kuwait
    15
    Refrigeration Tonnage =TR or RT, and KW/Hr=kilowat per hours,
    it is seems to me you are confusing , you need to know what you doing not merely conversion of unit, many people do the same mistake because they are not from this discipline, alway know that mechanical units are different to electricals as well energy, and you must know that energies and convertable but application of covertibilities must be known to the person want to convert it ,for example, in Hvacr we may have the energy (cooling load) given in Btu/hr you may convert it to kilowatt/hr, and we can convert these energies to electrical kilowat and mechanical horse power, try to know more about this, and you can download the engineering convert tools online
    Mar 2009
    U.S.A.
    320
    In SI: Joule is the unit of energy; Watt is unit of power. A KWhr represents power applied or consumed over an hour period. For motors: Volts X Amps X efficiency X PF= KW. Use the motor for an hour and the formula will yield consumption of power in KWhr.
    KWr is Kilowatts of refrigerating effect, and is the equivalent of 0.284 TR. But a compression refrigeration system moves heat, it doesn't convert electricity to heat as does a strip heater.
    Thus the definition of COP: (KW of refrigerating effect / KW of electrical input).... For an air conditioning system the ratio is about 4 to 5.
    So for your 10000 TR A/C load, the metric capacity equivalent is 35160 KW and steady state, you would need somethin around 7500 KW of electrical input. If that operated for one hour, it would consume 7500 KWhr of electricity...
  1. how can we calculation industrial refrigeration
    By lam sanh in forum System Optimization
    Last Post: 28-02-2011, 01:31 PM
  2. Refrigeration Piping Calculation
    By Kevin Yeo in forum Supermarket Refrigeration
    Last Post: 10-03-2010, 02:43 PM
  3. Refrigeration system charge calculation query.
    By refriengr in forum Fundamentals
    Last Post: 29-05-2008, 08:03 PM
