Thread: lennox unit
    Oct 2006
    west sussex
    lennox unit
    Hi guys
    I have a Lennox LGK075-H-2M, the pressure differential switch has disintegrated and I canít get one like yesterday, does anyone know if I can by- pass the switch temporarily to help the customer, this switch tells the unit whether the fan has failed or filters have blocked, etc, it connects to the KP01 board, 18 volt output, I need to know if we can do this safely without damaging the PCB board.
    AL
    Feb 2007
    2,479
    38
    Re: lennox unit
    Is there a reason why it can't be an universal one?
    RS does several different versions.
    Oct 2006
    west sussex
    Re: lennox unit
    there are re openeing tomorro!!
    Aug 2008
    Baltics
    55
    786
    10
    Re: lennox unit
    It seems it is not PCB which may be damaged. Supposing "LGK075-H-2M" is some induct AC? - I probably would make the bypass if I were you (if all is clear and works smoothely). Only, maybe, add a NO contact relay (instead of the diff relay) switched parallel with the fan so that controller knows that at least voltage to the fan goes?
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  2. Lennox unit problem
    By marc5180 in forum Air Conditioning
    Last Post: 08-11-2008, 10:16 PM
  3. Lennox Unit problem
    Last Post: 13-12-2007, 09:20 PM
  4. Thermo King OptiSet
    By REEFER-TEK in forum Transport
    Last Post: 06-12-2007, 07:23 PM
  5. TK basic micro-p features and functions
    Last Post: 05-12-2007, 06:25 PM
