15-06-2009, 08:01 AM #1
polar ice machine production problem
one ice machine with correct gas load starts off making good ice then decides to make a few good lumps and a few light lumps and part lumps. Anyone out there ever had this problem and perhaps can give me a clue.
15-06-2009, 02:10 PM #2
Re: polar ice machine production problem
shes a farked
imagination is stretching slowwwlymmm to beer or not to beer...........lets drink breakfast
15-06-2009, 03:35 PM #3
It could be one of many things that at fault, do you have any more info, temps, gas pressures etc???
19-06-2009, 04:59 PM #4
if it has correct gas charge in it i would suspect oil or restriction in the evap> hope this helps
20-06-2009, 06:47 AM #5
Water leaks?
Either cracked tank, leaking hose or valve or water dripping off the plate if it's dirty and has crap built up on it directing the water away from the tank.
This'll cause it to either run out of water before it makes a full plate of ice or add warm water to the tank if it works that way.
Sorry, not familiar with your machine.
If you publish more info it'd make it easier for us.
Problem with CPS Recovery/Recycling/Recharge Machine AR2788
By Gentleman in forum TransportReplies: 2Last Post: 29-05-2009, 12:30 AM -
Polar t315 ice maker problem
By nutfielder in forum DomesticReplies: 3Last Post: 29-12-2008, 07:16 PM -
Maintowoc ice machine problem
By jayshiv in forum Trouble ShootingReplies: 7Last Post: 05-07-2008, 11:31 PM -
water cooled ice making machine problem
By racktech2008 in forum Supermarket RefrigerationReplies: 2Last Post: 22-03-2008, 03:21 PM -
hoshi ice machine problem
By cretan in forum CommercialReplies: 2Last Post: 28-07-2007, 07:46 AM
