Thread: An evaporator inlet accumulator?
15-06-2009, 06:50 AM #1
Has anyone seen a kind of muffler/accumulator just after the capillary and before the evaporator inlet?
What's the role of this device then?
Thanks for reading
15-06-2009, 11:55 PM #2
Re: An evaporator inlet accumulator?
Give us a clue, what is it on?
16-06-2009, 02:55 AM #3
I 've seen similar things on milk vats, a Berkit liquid re-gen assembly, after TX vav. Cannot say Ive seen one fed with a capilary
17-06-2009, 06:03 AM #4
Guys,
That one is on a 2.2kw heatpump.
It has two little mufflers at each evaporator inlet. The mufflers are fed by the capillaries and their outlets lead to the evap inlets. They're exactly like the discharge line muffler.
I wonder if they're used for regulating the refrigerant flowing into the evap.
17-06-2009, 11:09 PM #5
Probably just filters unless they are the non-return valves, depends how big they are.
Heat pump = reversing flow.Brian - Newton Abbot, Devon, UK
22-07-2009, 11:27 PM #6
Thanks, Brian
[mobilehomerepair.com/media/img/nordyne/668710.jpg]
It's the like, and approx that size, too. Not longer than 2.5", less than 1" diameter.
It's makes me curious about its role in the system.
AWHP design - suction accumulator
By desA in forum Heat PumpsReplies: 9Last Post: 05-09-2010, 07:53 AM -
do u need an accumulator on a chiller?
By richard1900 in forum CPU OverclockersReplies: 8Last Post: 16-07-2010, 09:57 AM -
Does Accumulator really prevent liquid return to compressor?
By dsltung in forum Trouble ShootingReplies: 8Last Post: 08-03-2009, 03:12 PM -
suction accumulator control
By samiam in forum FundamentalsReplies: 6Last Post: 22-06-2007, 05:49 PM -
accumulator
By mohamed khamis in forum FundamentalsReplies: 13Last Post: 12-05-2006, 10:00 PM
