Thread: Re-equipped fridge freezer
14-06-2009, 11:25 PM #1
Just bought a new fridge freezer(FF) from a local charity Beko CDA660FW, with some estetic damage at a good price.
The first delivery FF never worked as the compressor was damaged. This organisation has given us another one. The second FF engine or compressor seems to be working all the time making a constant buzzing noise, we wonder whether this FF will also have a problem with the compressor or maybe the thermostat this time. Everything in the Fridge was frozen this morning and we had to put it at 1.5 from 2 out of 5.
The question is: is it normal that the compressor/engine makes this constant noise without almot stopping?
Does anyone know if this model has a recurrent problem with compressors?
thanks
A & J
15-06-2009, 03:07 PM #2
Re: Re-equipped fridge freezer
Sounds like lke you have a faulty one.
The compressor should only run for about ten mins and then be off for about ten to twenty mins.
If the compressor is running continuously then there is a problem with the freezer.
I would inform them that it is faulty. It seems that there may be more than just dents and scratches wrong with these freezers.
taz.
17-06-2009, 02:59 PM #3
thanks so much
Hotpoint FF200E Fridge Freezer Fault
By fredalfred in forum DomesticReplies: 107Last Post: 29-12-2012, 02:26 PM -
BOSCH Fridge/Freezer - fridge wont cool....freezer fine
By andy_lanc in forum DomesticReplies: 6Last Post: 25-10-2010, 01:25 PM -
Frigidaire FRC150 FF - fridge not very cold freezer forming frost!!
By TriciaA in forum Trouble ShootingReplies: 3Last Post: 04-08-2009, 04:24 PM -
Indesit FROST FREE Fridge Freezer - fridge not cold
By pauby in forum DomesticReplies: 26Last Post: 09-03-2009, 12:04 PM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM
