Thread: Design qestion
14-06-2009, 10:29 PM #1
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Design qestion
I recently started to work as backup in some fishing boat refrigeration, and peoples who makes cooling systems on fishing boats telling me a "story" that is much more efficient to cool glycol solution in refrigerant to glycol exchanger and than cool sea with that glycol in glycol to sea exchanger, than go direct with refrigerant to sea heat exchanger.
What is theory behind that? And are they talking fairytale?
15-06-2009, 12:48 AM #2
Re: Design qestion
nike123
your right they are telling fairytails. It is more efficient to transfer heat directly to sea water. They are trying to baffle you with bullsheep
15-06-2009, 03:57 AM #3
15-06-2009, 04:59 AM #4
Re: Design qestion
Well NIKE 123, I was going to say ....... But it is cool that you opened topic for general discussion.
magoo
15-06-2009, 05:00 AM #5
Re: Design qestion
They seem to be using a secondary loop for protection. Let the seawater-glycol act as sacrificial unit, to save the refrig-glycol system.
The secondary loop system will be less efficient since you need to establish a driving temperature gradient between refrigerant-glycol-seawater.Engineering Specialist - Cuprobraze, Nocolok, CD Technology
15-06-2009, 05:11 AM #6
Re: Design qestion
Nike 123 .
What ever you do be carefull on an written statements on performance. here , if anything goes wrong and the ships catch is de-rated for any refrigeration issues, the skipper/ compaqny will sue for lost catch potential.
So be very carefull on any advise and design.
magoo
15-06-2009, 09:43 PM #7
What design factors decides power comsumption
By kln in forum DomesticReplies: 3Last Post: 28-01-2008, 08:29 PM -
Efficient Water-Source Condenser Design?
By Enginerd in forum FundamentalsReplies: 4Last Post: 28-05-2007, 05:11 AM -
Replacement fo CO2 Bulk Tank refrigeration unit
By pabs_ref in forum CO2Replies: 31Last Post: 28-11-2006, 10:32 PM -
How to Design Refrigerated Cabinets
By Rayin in forum FundamentalsReplies: 5Last Post: 26-11-2006, 08:27 AM
