Thread: Leakage in Air Conditioning.
10-06-2009, 06:12 AM #1
Hello,
I just got through a unique problem while comissioning ACs in my data center. While i was inpecting the raised floor i found out that the space beneath the Precision Air conditoner was oily wet type. On inquiring the contractor, it specified that they have given a initial nitrogen pressure in the unit for testing it leakage, due to that it would have occured.
I want to know does that really happen during this nitrogen pressure or there is some other problem?
10-06-2009, 08:57 AM #2
Re: Leakage in Air Conditioning.
Id say theses a gas leak. Or unless when they pressure tested their bubble solution hasnt been wiped away?
10-06-2009, 01:26 PM #3
you need to find out where the oil came from. Maybe they put nitrogen in before finishing the pipework and pushed the oil out. Or maybe they connected their vac pump when the pipes still had nitrogen inside.
Any way you still need to know where the oil is from before you continue commissiong.Quidvis Recte Factum Quamvis Humile Praeclarum.
Latine dictum, sit altum videtur.
Si hoc comprehendere potes, gratias age magistro Latinae.
Data Center Air Conditioning
By adeelquick in forum Air ConditioningReplies: 1Last Post: 09-06-2009, 12:08 PM -
My freezer inner pipe leakage
By syaful in forum DomesticReplies: 3Last Post: 05-03-2009, 10:52 AM -
Pressure limitation for leakage detect
By Ding Kangzhi in forum Trouble ShootingReplies: 5Last Post: 29-07-2008, 12:02 AM -
Unique cooling system Port-A-Cool replaces air conditioning
By LC-Europe in forum New TechnologiesReplies: 20Last Post: 30-01-2008, 08:29 AM
