Thread: cooling tunnel
09-06-2009, 02:39 PM #1
cooling tunnel
hi!!
i have been given the job of finding the efficiency of a cooling tunnel...but don't know much about its design and inside working.
can u give me some info bout it....
09-06-2009, 03:31 PM #2
Re: cooling tunnel
With all due respect - if you don't know what it looks like, then how are we - the distance-challenged - going to be able to help?
Do you have some pictures?Engineering Specialist - Cuprobraze, Nocolok, CD Technology
09-06-2009, 03:38 PM #3
Re: cooling tunnel
Have a look here
16-06-2009, 07:18 PM #4
Re: cooling tunnel
hey...thanks a lot.
i took out the COP of the coolin tunnel it is 4.71..can u tell me its significance(as in is it good or bad???)
also can u suggest how can we improve it??
can u also suggest a way to find out the amt of refrigerant supply to compressor
16-06-2009, 07:39 PM #5
Re: cooling tunnel
Would you like me to do all of your assignment for you or are you prepared to do a little work yourself?
You will only learn by research, hard work and determination.
Energy saving Glycol filled dry cooler circuits
By Jasper in forum Technical DiscussionsReplies: 14Last Post: 19-06-2008, 02:18 PM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM
