Thread: cooling tunnel
    shm's Avatar
    shm Guest
    cooling tunnel
    hi!!
    i have been given the job of finding the efficiency of a cooling tunnel...but don't know much about its design and inside working.
    can u give me some info bout it....
    Mar 2009
    KZN, South Africa
    63
    2,212
    Re: cooling tunnel
    With all due respect - if you don't know what it looks like, then how are we - the distance-challenged - going to be able to help?
    Do you have some pictures?
    Oct 2001
    Nottingham UK
    5,668
    Re: cooling tunnel
    Have a look here
    shm's Avatar
    shm Guest
    Re: cooling tunnel
    hey...thanks a lot.
    i took out the COP of the coolin tunnel it is 4.71..can u tell me its significance(as in is it good or bad???)
    also can u suggest how can we improve it??
    can u also suggest a way to find out the amt of refrigerant supply to compressor
    Oct 2001
    Nottingham UK
    5,668
    Re: cooling tunnel
    Would you like me to do all of your assignment for you or are you prepared to do a little work yourself?
    You will only learn by research, hard work and determination.
  1. Replies: 5
    Last Post: 14-09-2009, 07:33 AM
  2. Energy saving Glycol filled dry cooler circuits
    By Jasper in forum Technical Discussions
    Last Post: 19-06-2008, 02:18 PM
  3. Compressor loading, cooling, and range of operation.
  4. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Industrial
    Last Post: 14-10-2005, 06:34 PM
  5. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Fundamentals
    Last Post: 13-10-2005, 05:14 AM
