    Jun 2004
    Wirral UK
    58
    68
    Glycol measurment
    Does any one know if there is a readily available table that decribes the specific gravity of a various %mix of Water and Propylene Glycol. I can mearsure the specific gravity and I know there is Propylene Glycol in the water chiller I need to know if the is enough or more acuratley if it is in the condition the customer believes it to be. And are there any other or better ways of measuring the freezing point of the solution
    "It's better to remain silent and be thought a fool than open ones mouth and remove all doubt"
    Oct 2002
    Re: Glycol measurment
    Blueboy,
    Is this link the sort of thing you are looking for ?
    http://www.mt.com/mt/resourcedetail/...MTg4NjM1_T&m=t
    Regards,
    Amar.
    Sep 2003
    ISRAEL
    72
    4,248
    Hello blueboy.
    On this site you will see what you need to measure the glycol gravity.
    http://www.misco.com/Digital/glycol.html
    There is an older gadget that looks like the one you measure the acid in cars batteries, I'm not sure about english name.
    Chemi
    Jun 2001
    N.Ireland
    1,630
    Hi Blueboy
    the cool pack sofware is what I use. www.et.dtu.dk/coolpack
    Kind Regards. Andy
    shogun7's Avatar
    shogun7 Guest
    The propylene glycol instrument is a dual scale hydrometer graduated in specific gravity and percent propylene glycol by weight at 60°F. A chart is supplied indicating freezing points, boiling points and per cent by weight volume equivalents. Length 305 mm. go here:
    http://www.ertco.com/hydrometer_propylene_glycol.html
    Jun 2004
    Wirral UK
    58
    68
    Thanks for all you help. I have measured the specific gravity as advised and it is 1.22 at 20 C does anyone know what the freezing point of the solution is and what % I have in the system
    master rinktec's Avatar
    master rinktec Guest
    Thumbs up Re: Glycol measurment
    The website that Chemi posted is the product that I use. I use the orange colored refractometer that they sell. It has a scale for ethylene and proplene as well as battery acid. They are very acurate and I do not have to compensate for the temperature. Well worth the investment.
  1. glycol charts
    By Feargal Loy in forum Technical Speculations
    Last Post: 28-03-2010, 03:19 AM
  2. Milk getting into glycol on chill press
    By balerjoe in forum Trouble Shooting
    Last Post: 06-09-2005, 09:41 PM
  3. Glycol Back To Refrigerant
    By JIMMYBOY in forum Supermarket Refrigeration
    Last Post: 16-08-2005, 10:54 PM
  4. Glycol water valves
    By eng_ab in forum Industrial
    Last Post: 03-06-2005, 09:15 PM
  5. which glycol to use ?
    By dchatta in forum Refrigerants
    Last Post: 12-07-2004, 09:26 AM
