    chillzilla's Avatar
    chillzilla Guest
    Traction coefficiant
    Can someone tell me what traction co-efficiant means in relation to refrigerant oils ?
    Sep 2005
    42
    191
    Re: Traction coefficiant
    I'm not a RE.....
    but in plain english....
    it's how hard it is to pull the oil appart / how well it's stuck together..
    something with a low traction co-efficiant will form very small dropletswhen spilt
    something with a high traction co-efficiant will form larger droplets when spilt
    it's also relevent when running over gears .. how much oil they pick up etc..
    I (guess) it would effect oil return to the compressor too ? larger droplets will be easier to return than smaller ones ?
    Auckland
    74
    3,357
    38
    I am picking it is "miscability" [ spell check required . ]. But I have been wrong before.
    magoo
  1. Traction coefficient
    By reggie in forum Technical Speculations
    Last Post: 26-03-2003, 09:23 AM
