Thread: Charging a homemade system
07-06-2009, 09:20 PM #1
I am building a sluchice machine for my dormitory kitchen. The plan is to use an old 160 W hermetic compressor from a R12 freezer. I’m interested in building a new evaporator that is better for the purpose of making sluchice. This of cause involves discharging the old system and recharging the new one. The problem is that I have no practical experience or access to special tools like vacuum pumps and so on. The plan is to recharge the system with R290 Propane, because I can get access to propane and it seems I will deal with similar pressures ass the originally R12 filling. I have the following questions:
- Will I kill myself in the process, in some exploration?
- Will I kill my friends because the compressor makes a spark later on?
- How do I calculate the filling size?
- Can I use ordinary camping gas?
- How do I empty the system for air and R12 without a vacuum pump? (Is it may be possible just to dilute by blowing propane thru the system for a while?)
- Where do I find a good expansion valve solution (not to expensive)
Hope you can help me, maybe even save the life of me and my friends. If you know a place where I can find guides or other relevant material please let me know
07-06-2009, 11:16 PM #2
Re: Charging a homemade system
- Anything is possible.
If you know a place where I can find guides or other relevant material please let me knowBrian - Newton Abbot, Devon, UK
08-06-2009, 04:11 PM #3
Oeps, if we don't here from that guy again in a few days,we now why!!! the wonders of Propane.(LOL)
Ice
08-06-2009, 05:39 PM #4
Hmmmm...
No knowledge.
No experience.
No tools.
Non-standard components.
Non-standard refrigerant.
Dangerous refrigerant.
What's wrong with this picture?
Is there anything right with this picture?
08-06-2009, 08:18 PM #5
I hear what you are saying of cause not the answer I was hoping for, but on the other hand sort of what I was expecting.
It would be so cool to make this work with a homemade evaporator. Now I think I will use a brine to cool my slush-ice production surface, this way I can use the existing evaporator.
Thanks for your replies.
If anyone has other ideas for the project please let me know
08-06-2009, 09:13 PM #6
As a beginner project, I would suggest finding a cheap system that works, take it all apart, put it all back together, and make it work again. If you can accomplish this, you may be ready for the next step.
08-06-2009, 10:52 PM #7
As Gary says but with the right equipment to hand.
System sizing for heat and manual J
By Larry2 in forum Heat PumpsReplies: 5Last Post: 25-06-2008, 10:58 AM -
18 seer AS charging problem,best way?
By nagzul in forum Air ConditioningReplies: 3Last Post: 01-05-2008, 07:44 AM -
charging a system
By paulwild in forum FundamentalsReplies: 9Last Post: 26-12-2007, 05:23 PM -
Charging a system
By shark26 in forum FundamentalsReplies: 32Last Post: 31-01-2006, 06:41 PM -
Automotive A/C Vent Temp Range vs System
By Don Browney in forum Air ConditioningReplies: 1Last Post: 15-05-2002, 06:19 AM
