Results 1 to 1 of 1
Thread: Hotpoint fridge/freezer
05-06-2009, 07:41 PM #1
Hi all got aproblem with Hotpoint fridge/freezer model no RFA60P. At first neither section was working although the compressor was running. Fitted an access valve with cabinet switched off, guage went straight into a vacum. I pressure tested with ofn to a pressure of 6 bar, this seemed ok, so I vaced the system and weighed in correct charge of R600A. Now the freezer section is working fine but fridge section isn't refrigerating at all. It has a solenoid device (3 - way) in the capilary line which isn't energizing. Does this energize on temp cut in or cut out?? Could the fridge section capillary be blocked, if so is it repairable in any way??
Hotpoint FF200E Fridge Freezer Fault
By fredalfred in forum DomesticReplies: 107Last Post: 29-12-2012, 01:26 PM -
domestic problems- hotpoint mistral fridge/freezer
By Northdude in forum DomesticReplies: 49Last Post: 02-10-2011, 08:21 PM -
Hotpoing fridge/freezer HELP NEEDED!
By graham125 in forum DomesticReplies: 7Last Post: 20-02-2009, 06:46 AM -
Need help choosing an American style fridge/freezer
By mclovin in forum DomesticReplies: 11Last Post: 12-09-2008, 01:56 AM -
Hotpoint FFS70 defrosting and high temp leds lit
By Aitcho in forum DomesticReplies: 13Last Post: 07-09-2008, 01:29 PM
