Thread: Psychometric Charts
21-05-2001, 08:52 PM #1
I need some help. At college I went through the whole psychometric part of the course. And have never used one since.
I can visualise the more experienced techs absolutely aghast at this statement. But , could someone care to explain, divulge on this forum where and when they would resort to using these charts?
21-05-2001, 10:15 PM #2
I think most techs wouldn't except during a service call and you had to have proof, or if you are going to put in a new system maybe. Definitely if you are working in a clean room or room with highly sensitive electronics. Even then though they usually have humidity sensors etc. throughout the room.
I have never used one since school either...:D
Dean
Subzero*psia
Extinction is simply proof of failure to adapt.
02-01-2003, 05:19 AM #3
The chart is useful if you need to estimate re-heat capacity for a low RH% application ( w/o using a dehumidifier )
Also to predict mixed air properties in AHU's.
Maybe for knowing how much moisture is removed or added to a system ( when dehumidifiers or humidifiers are used )
I think you can have these charts on a PDA and very handy.
glycol charts
By Feargal Loy in forum Technical SpeculationsReplies: 2Last Post: 28-03-2010, 03:19 AM -
p-h charts
By vikki in forum Technical SpeculationsReplies: 9Last Post: 23-09-2006, 11:00 PM -
P-T Chart(s)
By HVACGod in forum RefrigerantsReplies: 8Last Post: 24-05-2006, 12:17 AM -
superheat/subcool charts.
By Temprite in forum Air ConditioningReplies: 10Last Post: 14-08-2005, 06:56 AM -
psychometric charts/pressure - heat charts
By bilmul in forum Tools and CalculatorsReplies: 8Last Post: 28-03-2004, 11:22 PM
