Results 1 to 17 of 17
Thread: Eutetic plates
    May 2009
    Querétaro México
    Eutetic plates
    Hello to all,
    I need to find a way to estimate the cooling capacity of the eutetic plates, I know that the frezing point depends of the quantity of salt in the water solution inside the plate. but I want to be able to estimate the amount of heat that can be remove, mesure by liters (or gallons ) of eutetic solution.
    Thanks in advance
    Pierre
    Mar 2007
    118
    Re: Eutetic plates
    Quote Originally Posted by A/C MAX View Post
    Hello to all,
    Thanks in advance
    Pierre
    Try the Dole website
    http://www.doleref.com/products.html
    They still make eutectic plates and may have sizing info online.
    Re: Eutetic plates
    Personally I do not like salt solution as the solution tends to stratify, prefer glycol. Nothing worse than a busted plate generally at the top because the water content has frozen.
    magoo
    May 2009
    Querétaro México
    Re: Eutetic plates
    Ok, thanks Guys, I'm already send an Email to DOLE, to see if I can buy some eutetic plates, they have a nice brochures, with nice technical information...
    I read a couple of very nice old post here in this forum about this plates, they are heavy, and reduce the weight capacity in the delivery truck, BUT, in the other hand, they are SIMPLE, and do not requires sofisticated "on board" electronics, and don't mess arround with the truck engine.
    This is an advantage in my country, due to the fact of the high price, and hard to get parts for Carrier and Thermoking, in the small to medium delivery trucks segment.
    Thanks for your help!
    Mar 2007
    118
    Smile Re: Eutetic plates
    Magoo, the entire plate freezes with or without any separation. This is factored into the design. I have worked on transport systems with Dole cold plates that are 50 yrs old and going strong. And yes they ARE simple. I have no financial connection to Dole, but have been to the factory and the quality built into these plates is unlike anything left in America today
    Re: Eutetic plates
    Hi tbirdbird.
    Don't get your shorts in a bunch.
    I am offering past experince. I am keen to see what the Dole offer, as I have an business interest.
    Thank you for input.
    magoo
    Oct 2003
    5,630
    Re: Eutetic plates
    magoo
    They always freeze to a solid, even the name says it: eutectic. The purpose is that they solidify.
    I'm making often cold plates and this since 1990 and we have the best results with salt.
    Stratification with salt, how's that possible if all the salt is disolved in the water?
    A big con for glycol is that it's initial purpose is to prevent that a liquid solidifies. It becomes more a slurry when it freezes, not a solid block and that's just what we need: store as much as possible latent heat.
    Re: Eutetic plates
    To Peter dash one.
    I bow in your presence, arise Sir Peter .
    magoo
    May 2009
    Querétaro México
    Re: Eutetic plates
    Hi Peter, a real pleasure to meet you, I read all your articles about eutectic plates in this forum, as a matter of fact, searching this subjet in the web, is how I reach this forum, thank for share your knowldge
    Dole have a very nice and complete information about eutectic plates, they include some cold capacity in BTU for each plates, but still I wondering how we can estimate the cold capacity in KW or BTU for a self designed plates.
    Im use to buy some plates for the Italian manufacter FIC, and they works great too, but this time, I looking for some self desing.
    Have a nice weekend
    Pierre
    Oct 2003
    5,630
    Re: Eutetic plates
    Pierre, if I can help you with the design or pictures, let me know. I don't pretend mine are the best but I'm speaking out of practical experience.
    I also grinded open several other plates from larger manufacturers to see how they do it.
    The easiest way to weld the seams is roll welding but it's not easuy to find someone who can do this.
    May 2009
    Querétaro México
    Re: Eutetic plates
    Hi Peter
    Thanks, well I want to use this plates in a small isothermique Renault Kangoo, for medium temperature range 2° to 4°C, my idea is freze the plates trough a chiller, to avoid the instalation of the compresor inside de vehicle, so my first step is calculate the load, and the size of the plates.
    As soon as I have mi first sketches I let you know
    Thnks Peter, and have a nice week!
    Oct 2003
    5,630
    Re: Eutetic plates
    We also have a Kangoo but not cooled
    1 st requirement: isolate it very well
    Do you have a sliding door on the side as we have?
    Proposal: 1 plate on 1 side and one just behind your seats, eutectic point at -10°C to -12°, thickness 4 cm.
    Concerning circulating brine: in order to solidify a brine at -10°C, you need a brine at a temperature of -15°C, so you need to evaporate at -20°C, -22°c, so not so very efficient.
    But it's of course possible. Circulating a brine at -22°C will also need a strong pump to circulate.
    For a Kangoo, a 1/2 Hp will be enough. Why not install the compressor in a small corner in the van and your condensor on the roof?
    Another option is some bigger plates wit he compressor between in an isolated space. The plates are behind a small wall wit on top a small fan.
    As soon you need cold in the space, a thermostat engages the fan and 'sucks cold' from behind the wall.
    Something like this http://www.frigoblock.de/index.cfm?m...TOKEN=87213990
    May 2009
    Querétaro México
    Re: Eutetic plates
    Ok, Peter
    Well yes, we have the Kangoo with slide door too, the insulation are made by the French company EPC, thanks for the information about the frezzing points...
    My concern about install the compresor "on board" is the weight, the load capacity in this small vans are only 500 kg, so less weight could mean more delivery capacity,
    1/2 HP semihermetic compresor could weigh 35 Kilogram or so, use a hermetic compressor onborad I guess its not recomended, what do you think?
    RGDS
    Oct 2003
    5,630
    Re: Eutetic plates
    Indeed, a Kangoo can't charge that much.
    We mostly use hermetics for the price and this gives nver real problems if the place in the van is right chosen.
    Weight compressor = +/- 23 kg.
    If you want to go for a brine cooler, I then should made a brine cooler from a 1.5 HP hermetic and a PHE and a circulating pump and some sort of a buffer tank.
    How will you accomplish coupling and decoupling?
    We experimented also once with special gas couplings to disconnect a counter. But you lose always a little bit.
    Will anyhow cost a lot more then installing it in the van.
    To reduce space, you could go also go for a watercooled condenser. You then have to connect power and water
    May 2009
    Querétaro México
    Re: Eutetic plates
    Ok Peter, well looks if I frozze de plates with a Chiller, then I have to use a 3 times bigger compressor, it's a good point for shure.
    Coupling and decoupling the circuit,could be made trough some "quick connect" devices, and yes the idea were use brine instead refrigerant, a more "envioromental friendly" solution, but again, this ad some more money to the equippement... I got your idea.
    Well, looks the key here is try to develope the lightest compressor/condenser, and found the right place for fix it. Im going to make some research for small water cooled condensers.
    How many liters of eutetic solution do you estimate for this application?, some years ago, I bring to México ( as a consulting service) the French company OLIVO COLD LOGISTICS http://www.olivo-logistics.com/ this company made some plastic insulated containers colled by CO2 or by eutetic plates, They are available here, and maybe I can froze this plates in a frezzer @ -20C or more, and then put in a truck inside a cabinet with a fan to control de temperature, but I don't know how many plates or liters of solution were needed.
    Thanks for your time and help Peter!
    Pierre
    Feb 2009
    telford
    2,090
    33
    Re: Eutetic plates
    what a post lots of info,these systems were very popular but the weight was a problem,very simplistic to operate many variations ,i use them for customers who sell maggots as the ammonia given off does not rot them,
    Re: Eutetic plates
    well there ya go a busted plate.
    magoo.
  1. Personalised number plates
    By fridg in forum Chit Chat & Service Stories
    Last Post: 27-03-2010, 11:18 AM
  2. Evaporator Flash over
    By Chef in forum Fundamentals
    Last Post: 25-06-2007, 11:02 AM
  3. Cold plates
    By Peter_1 in forum Commercial
    Last Post: 10-05-2006, 07:52 PM
  4. Eutectic plates
    By Temprite in forum Commercial
    Last Post: 31-05-2005, 12:13 PM
  5. Orifice Plates
    By Tony in forum Industrial
    Last Post: 18-07-2002, 09:51 PM
