Results 1 to 1 of 1
Thread: Mitsubishi SRK35ZG-S
04-06-2009, 11:49 AM #1
I have had this unit professionally installed at home. Happy with everything except running it in Auto mode.
In Heat and Cool modes the thermostat works fine, but in Auto the temperature keeps rising/falling. I have had the installer look at it and he can see the problem, but now tells me that Mitsubishi have said that there is a +/- 5 deg variation before the temperature starts to adjust. This means that with the room temp set at say 20 deg, we have to put up with a range from 15 to 25!!
I have looked through the manufacturers available info but it does not mention tolerances anywhere.
Someone please tell me that this is not working properly.
The installer is getting another inside unit to replace the existing one, but if Mitsubishi are right then it won't make any difference.
Comments would be appreciated.
Dave
Mitsubishi Approved
By R1976 in forum Air ConditioningReplies: 8Last Post: 01-06-2009, 06:08 PM -
Few question about Mitsubishi Heavy Industrial air condition
By fireduck in forum Air ConditioningReplies: 55Last Post: 12-05-2009, 02:35 PM -
[Ask] Mitsubishi rotary compressor
By felixfab_93 in forum Refrigeration BooksReplies: 1Last Post: 18-12-2008, 10:48 AM -
Mitsubishi Light Truck Refrigeration
By Mastercool in forum TransportReplies: 2Last Post: 23-11-2007, 06:15 AM -
Mitsubishi compressor lock
By marc5180 in forum Air ConditioningReplies: 29Last Post: 08-10-2007, 05:48 PM
