01-06-2009, 07:42 AM #1
Refrigeration Package System for our Coal Gasification Project
Hi All,
Can you please help to find the vendors who can supply the entire refrigeration package for our coal gasification prject ( For Rectisol process) in India.
The technical specifications of the unit are as follows:
The designPackage Process parameters are as follows:
- Refrigerant Fuild : Propylene
2. Total Refrigeration duty : 16439 KW= 4675 TR (Tonnes of Regn.)
3. Propylene flow : 123.41 MT/hr
4. Refrigeration Compr. Duty : 7.536 MW (at shaft)
5. Cooling water consumption : 17160 m3/hr (Delta = 10 C)
Hope you will be kind enough to share this information with me.
Best regards,
Naveen Ahlawat
Senior Manager
navahlawat123@gmail.com
16-06-2009, 05:45 AM #2
Re: Refrigeration Package System for our Coal Gasification Project
17-06-2009, 06:08 AM #3
Thanks Mr. Amrish for your prompt reply.
17-06-2009, 11:15 PM #4
do you have to use this refrigerant?
20-06-2009, 11:12 AM #5
No. No.. Propylene will be used as refrigerant in this system
20-06-2009, 11:22 AM #6
04-07-2009, 08:57 AM #7
Try GEA Process Engineering (India) Pty Ltd
Block No 8 P. O. Dumad, Savli Rd., Vadodara, 39174
Tel +91 (0) 265 3061 755/756
They have Chemical & Petrochem guys
Superheat and Subcooling
Refrigeration system simulation and optimization
By autt in forum System OptimizationReplies: 7Last Post: 05-12-2008, 02:59 PM -
Refrigeration system design
By sachin9782 in forum RefrigerantsReplies: 4Last Post: 19-11-2008, 07:27 PM -
Refrigeration system charge calculation query.
By refriengr in forum FundamentalsReplies: 0Last Post: 29-05-2008, 08:03 PM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM
