Results 1 to 2 of 2
23-06-2004, 08:42 AM #1
Dual 2 ton compressor help wanted
2 compressors in 2 ton unit
Actually i am trying 2 make 2 ton aircondioner using 2 compressors ( 1.25 ton and 0.75 ton )
Can any body help me in this regard with material or any book u ppl can recommend?????????
Our nose is our personal air-conditioning system: it warms cold air, cools hot air and filters impurities
01-04-2005, 03:24 AM #2
Re: Dual 2 ton compressor help wanted
i know this is an old post but i couldnt help it. This is very possible. I have done it myself. Actually it was tried by some companys to provide 2 stage cooling and worked quite well. Biggest problem is oil. Without an equalizer between the compressors the oil will end up in one starving the other. You might need the help of a machine shop to fit the equalizer.
dual source heat pump
By Lc_shi in forum New TechnologiesReplies: 29Last Post: 12-08-2010, 02:24 AM -
HELP with LG dual zone
By stretch in forum Air ConditioningReplies: 5Last Post: 05-08-2006, 07:22 AM -
Dual Scroll Compressor
By ernestlin in forum Technical DiscussionsReplies: 7Last Post: 27-06-2006, 04:14 AM -
Need help with a dual compressor display case
By kengineering in forum Technical DiscussionsReplies: 15Last Post: 15-03-2006, 07:32 PM -
Dual vs. Parallel Piped
By Cool Temp in forum IndustrialReplies: 0Last Post: 28-09-2005, 03:32 PM
