Results 1 to 2 of 2
    Jan 2009
    sunny norfolk
    81
    carel controller hidden reset button
    hi
    Panel mounted controllers as fitted to commercial refrigeration cabinets
    I found something interesting today that may be of help to others:
    Carel controllers PJZ, EASY and others have a factory reset function for faulty controllers. If you switch the cabinet off, hold the SET button and switch the cabinet back on, this will restore carel factory program (not the set up parameters)
    I have used this function a couple of times and it has cured the fault…………so far!!!!!!!
    Also if you hold the up key, this allows the compressor to run regardless of cabinet temperature as a couple of customers have found out (fridges running at -12c)
    steve
    Feb 2009
    telford
    2,092
    33
    Re: carel controller hidden reset button
    very interesting mr bond,you have discovered our secret,is it to be your epitaph in our quest for world domination, sreiously i will bear it in mind thanks
  1. Carrier Transicold Container Problem
    By Shamel in forum Transport
    Last Post: 23-01-2012, 11:23 PM
  2. carel easy controller
    By Andy AC in forum Commercial
    Last Post: 25-09-2009, 06:53 AM
  3. Carel controller
    By Vucko Antarktik in forum Technical Speculations
    Last Post: 11-04-2008, 12:04 PM
  4. Carel temperature controller issues
    By tegwin in forum Electrical
    Last Post: 30-01-2008, 03:10 PM
  5. Carel Controller
    By jrajmann in forum Air Conditioning
    Last Post: 05-06-2007, 07:37 PM
