Results 1 to 10 of 10
    Jan 2009
    sunny norfolk
    81
    Smile fujitsu multi split, how it works??
    hello
    i am a commercial refrigeration engineer so please be gentle!!
    my office has just had a new fujitsu multi split fitted and i have a couple of questions if anyone could please help
    fujitsu multi split 3 x indoor units and one outdoor unit with 3 sets of 3/8 pipes from the unit to each coil and one compressor
    1. all pipe runs are of diffrent lengths so how will it ensure correct flow of refrigerant to each
    2. if one indoor unit is switched off what will the outdoor system then do
    3. is there any drawbacks to this type of system
    thanks
    steve
    Jan 2009
    sunny norfolk
    81
    Re: fujitsu multi split, how it works??
    little bump
    Aug 2008
    Baltics
    786
    I see it so.
    If all inside units are switched off, all solenoid valves are off, compressor is off.
    If at least one unit is on, compressor slowly starts, the corresponding solenoid valve opens, compressor begins pumping the refrigerant in the corresponding unit's circuit adjusting its speed, thus pressure(s), thus temperature(s) to satisfy the temperature demand at the corresponding unit's premises.
    If the second unit is on, then the third one is on, their solenoids are on, compressor's speed increases, etc, etc, to satisfy the increased demand for air temperature.
    The demand at all premises being satisfied, compr slowing down, then stops. What do the solenoids at that time, I dont know.
    All the units off, all solenoids off.
    Only one mode is possible - if one inside unit is set to cooling, for instance, it is impossible to set an other unit for heating.
    Jan 2009
    sunny norfolk
    81
    so this type of systejm could only be used with a vari speed compressor.
    that makes a lot of sense now, thanks for that
    Aug 2008
    Baltics
    786
    Invertor, or frequency converter.
    Jan 2009
    sunny norfolk
    81
    thanks for that
    Also, some multisplits may use electronic flow control valves to regulate the gas flow.
    Jan 2009
    sunny norfolk
    81
    hello brian, so how would an electronic flow control valve work i.e. what would control it
    thanks
    steve
    Probably by monitoring the pipe temperatures.
    Jul 2008
    Australia
    Fujitsu units use a series of Fujikoki electronic expansion valves usually 1 main valve & 1 for each head. No solenoid valves. The set starting point for each valve is pre- programmed & various sensors let the controller know what setting is needed for each valve. the valves do not shut fully but are 10% open even when the head is off.
  1. Replies: 18
    Last Post: 15-04-2009, 08:42 PM
  2. Toshiba multi split runs non-stop
    By expat in forum Air Conditioning
    Last Post: 30-10-2008, 09:25 AM
  3. Faulty Fujitsu invertor wall split
    By nick_nst@aapt.n in forum Trouble Shooting
    Last Post: 30-06-2008, 08:04 PM
  4. Multi Split and VRV
    By Abe in forum Air Conditioning
    Last Post: 20-08-2007, 01:12 PM
  5. Ascon ac multi split
    By mike live in forum Air Conditioning
    Last Post: 30-06-2006, 08:52 PM
