Results 1 to 9 of 9
Thread: Solenoid Valves
    Nov 2001
    Shropshire
    59
    260
    23
    Solenoid Valves
    An unusual one this.
    I need a valve (12v coil) that will switch NOX (Nitrous Oxide)
    The valve needs to have between 1/4-3/8 (max 1/2) flow and should handle a MOPD of 1000psi (70bar) ish.
    Has anyone seen such a thing at a reasonable price in the UK.
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Solenoid Valves
    Never heard of a solenoid with MOP of more then 500psi.
    Maybe try one from the steam or hydraulic industry, they work in these pressures.
    the coil will be a bigger problem.
    Chemi
    rbartlett's Avatar
    rbartlett Guest
    Re: Solenoid Valves
    having trouble meeting that 2 hour call out deadline??
    cheers
    richard
    Nov 2003
    North Wales
    48
    74
    21
    Re: Solenoid Valves
    I was searching the web and I came across this site http://www.technobots.co.uk/en-gb/dept_205.html.
    They mainly deal with pneumatics, but they have a range of low voltage, high pressure solenoid vavles.
    Hope it helps.
    Neil
    Jan 2003
    East Anglia
    1,160
    Re: Solenoid Valves
    Sorry John,
    But not even nox will make the company leyland/daff vans go any faster.
    Raymond
    Nov 2001
    Shropshire
    59
    260
    23
    Re: Solenoid Valves
    Ok so here's the problem, NOX will rot most things I need nylon/teflon etc,, the valve orifice needs to be 1/4 MAX.
    The coil power is the issue, can I either...
    A. Use an existing solenoid with the usual 300-500MOPD and use a larger coil say 40w instead of 14w.
    B. Use a 6v coil powered at 12v...
    Oct 2001
    Nottingham UK
    5,667
    Re: Solenoid Valves
    Ohm's Law states that this is a no brainer
    Nov 2001
    Shropshire
    59
    260
    23
    Re: Solenoid Valves
    Quote Originally Posted by frank
    Hi Frank.
    Yep I quite agree, BUT the duty cycle of the valve is about 3 seconds on hours off, I figure that if the coil is given pleenty of space and with that kind of duty cycle it may work.
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Solenoid Valves
    Hi Jon.
    I think it should work and not burn.
    I was called to a house today that wes connected to the main power by an idiot, connected the three phases wrong ie one to the "0" two othres ok and inatead of the third, the "0".
    The poor fridge got 400 volt supply, survived for one day.
    You should have seen the fan running at 5000rpm.
    I thought of your problem and I think you are ok.
    Chemi
  1. Stainless steel valves
    By Tycho in forum NH3
    Last Post: 05-11-2008, 02:16 PM
  2. Hinari and how far to open valves
    By stryker in forum Air Conditioning
    Last Post: 14-04-2008, 01:47 AM
  3. Blistering Hot Gas Solenoid Diaphragm Issue
    By dewars_aus in forum Trouble Shooting
    Last Post: 18-07-2006, 09:37 PM
  4. Glycol water valves
    By eng_ab in forum Industrial
    Last Post: 03-06-2005, 09:15 PM
  5. Positon of tx valves
    By Les Stuart in forum Trouble Shooting
    Last Post: 16-11-2003, 04:43 PM
