Thread: Calculating capacity
27-05-2009, 02:47 AM #1
I have been asked to resurrect an old air conditioner that was decommissioned twelve years ago. My problem is that I need to replace the condenser but I can not find any identification on the air conditioner or condenser therefore I have no idea what capacity condenser to order. My guess would be somewhere around the 100Kw plus mark looking at the size of the coils etc. It is a DX system, package unit with a remote condenser. Can air conditioner capacity be calculated by using details from the condenser such as tube size and length? If so can anyone give the formula? Cheers.
27-05-2009, 06:31 PM #2
Re: Calculating capacity
is the condensor beyond repairs???
Ice
27-05-2009, 06:43 PM #3
if what you say is true,and there are no more indications on the unit,the best thing near gessing is to take a lot of notes. thickness of tubes,lenght,total amount of tubes, how are they connected, howmany turns and splits. howmany connections in & outgoing, finns are 1 / 2 / 3 mm apart and so one. than compare whit some fabricators and see if you get lucky. thats the easy way. you can also calculate yourself throug the hole thing,but thats a bit more difficult(i think)
Ice
27-05-2009, 07:23 PM #4
Best way is doing it via the compressor type or the fan coil
28-05-2009, 02:10 AM #5
28-05-2009, 06:17 PM #6
How to increase pool heater capacity?
By Drew in forum CommercialReplies: 104Last Post: 13-06-2009, 05:25 AM -
Sensible Heat Factor / capacity of Inverter split Systems at part load?
By Greengrocer in forum Technical SpeculationsReplies: 31Last Post: 09-02-2009, 04:57 PM -
Freeware for calculating coldroom capacity
By Rosafung in forum Tools and CalculatorsReplies: 3Last Post: 07-12-2008, 01:34 PM -
R-407C and Coil Capacity
By glabah in forum RefrigerantsReplies: 5Last Post: 03-06-2006, 11:36 AM -
TEV capacity related to pressure drop
By DaBit in forum CPU OverclockersReplies: 8Last Post: 06-12-2002, 05:11 PM
