24-05-2009, 06:05 PM #1
Thermoking MD II SR will not crank?
Have MD II SR that will activate fuel pump, preheat, but will not crank. Any suggestions appreciated. Thanks.
27-05-2009, 12:42 AM #2
Re: Thermoking MD II SR will not crank?
have you hot wired the starter solenoid,make sure the battery is fully charged,if power is good 12volts at panel try jumping wire[2] across to 8s maybe starter relay in panel or bad earth at starter what is the history, has fault just appeared.
27-05-2009, 12:45 AM #3
by the way your post is in the wrong section,try the transport section
28-05-2009, 03:50 AM #4
All connections and voltages are good. Looks like a
bad starter, won't energized when hot jumped. Thanks.
29-05-2009, 12:25 AM #5
crank case heaters in scroll compressors
By abbasi in forum FundamentalsReplies: 19Last Post: 03-08-2010, 03:04 AM -
Thermoking MD11SR
By Chris2005 in forum TransportReplies: 4Last Post: 18-01-2010, 06:17 PM -
thermoking container manuals
By jamcool in forum TransportReplies: 68Last Post: 18-11-2009, 07:53 PM -
Thermoking Sentry Max II Manual
By Dguzman in forum Refrigeration BooksReplies: 1Last Post: 16-12-2008, 06:47 PM -
hotgas and crank case pressure regulator
By abbasi in forum FundamentalsReplies: 8Last Post: 27-02-2006, 01:54 PM
