24-05-2009, 12:57 PM #1
Kotza: typing error in manual ????????
Hi all, who am I to disagree with the authors of the Kotza refrepair manual. Whilst perusing this great book I stumbled across something on page 29 that seemed to throw a curve ball at me, and I quote:
"If the superheat is too large, the expansion valve will be closed and will allow very little liquid to pass through. As the evaporator contains very little liquid, the refrigerating capacity is small and the change in temp for the air is rather small"
and further on:
"If the superheat is too small the expansion valve opens too much and allows too much liquid to pass through."
Is it me that has got his lines crossed or what??
24-05-2009, 01:08 PM #2
Re: Kotza: typing error in manual ????????
It's talking about the past tense rather than what it should do.
It's telling you how it got it that state.
It's poorly written really.
and go get a cuppa
25-05-2009, 11:02 AM #3
I have the French manual and there's a little difference (translated to English):
If the SH is too high, then the expansion valve is too much closed and it let pass not enough liquid.
The evaporator contains to less refrigerant resulting in a too small capacity
If the SH is too small, the EV is to wide open and let pass too much liquid.
This sounds better?
Poor translation (also mine I suppose) .Last edited by Peter_1; 10-07-2010 at 07:09 PM.
10-07-2010, 06:46 PM #4
Hey thats nothing, look at the part wind diagrams in Refrirepair manual...
Frick screw compressor SGC3515 overhaul manual
By cjlee74 in forum IndustrialReplies: 10Last Post: 13-10-2010, 08:49 AM -
Airwell BS 36 Technical Manual
By Electricliff in forum Air ConditioningReplies: 14Last Post: 17-12-2009, 12:04 PM -
Creating Troubleshoot manaul (Fault Code Manual)
By Roan in forum Trouble ShootingReplies: 2Last Post: 25-02-2009, 08:11 PM -
daikin service manual help
By omurcelik in forum Air ConditioningReplies: 2Last Post: 28-05-2008, 01:42 PM -
HP Switches (Manual or Auto)
By Latte in forum Technical DiscussionsReplies: 9Last Post: 02-06-2005, 07:48 PM
