Thread: single phase 208v
24-05-2009, 12:10 AM #1
single phase 208v
good memorial day weekend to all,
question:
on a single phase 208 volt a/c compressor (Tecumseh)
i am not finding any relay to drop out the start winding
as is the case with a typical 115v slit phase compressor.
It is a CSR motor with one cap.Is a centrif.switch living
inside the hermetic???
I have experience with split phase and three phase
but need some help with the above. thanks!
Best Regards
24-05-2009, 06:37 AM #2
Re: single phase 208v
Wikipedia:
A variation of the centrifugal switch used a changeover contact to ensure that the auxiliary windings remain in the circuit through a running capacitor. These motors are called two-value or capacitor start capacitor run motors.
24-05-2009, 07:18 AM #3
Your motor is evidently capacitor start and run. One and the same cap ensures both the start and the run phase shift.
generic single phase contactor?
By paul_h in forum ElectricalReplies: 9Last Post: 06-02-2009, 08:28 AM -
single phase scroll comp direction
By bangoman in forum Air ConditioningReplies: 2Last Post: 19-09-2008, 05:47 PM -
SR2 50 models electric SBY diagonostics made simple
By absolute-zero in forum TransportReplies: 5Last Post: 04-01-2008, 05:11 PM -
Variable speed drives for single phase motors
By PRESS in forum Air ConditioningReplies: 10Last Post: 10-12-2007, 07:23 PM -
Single phase contactor
By Andy T in forum CommercialReplies: 9Last Post: 23-10-2006, 01:45 PM
