    pinkpanther's Avatar
    pinkpanther Guest
    Sizing of Heat pump
    Hi guys, i would like to heat up an enclosed area of 40cm x 40cm x 50cm using a heat pump. The maximum temperature should not exceed 122 degrees Fahrenheit.
    Is there a way to calculate or derive a value where i can estimate the size of heat pump needed?
    A heat pump would be to use the condenser heat instead of the evaporator unit.
    11,025
    Re: Sizing of Heat pump
    That's a very small area to utilise a heat pump on.
    Perhaps a Peltier device may be more suitable.
    Mar 2009
    KZN, South Africa
    64
    2,212
    Quote Originally Posted by pinkpanther View Post
    It should, in theory, be possible. Suitable small compressors do exist.
    Perhaps you could explain more about what is in this enclosed area. For instance, are you heating air, machine parts, other substances? What temp do you start from? How critical must the final temperature be? Why a heat-pump, in particular - other than for energy-efficiency?
    pinkpanther Guest
    i'm doing it for a school project, which has its requirements set at using heat pump. Its meant to be used as a food dryer. Temperature isn't that critical, just below 122 degrees fahrenheit rising from room temperature.
    Mar 2009
    KZN, South Africa
    64
    2,212
    Have you determined the required heat-load for the food-dryer?
    May 2008
    66
    802
    the compressors from waterdispensors,ore domestic icecube makers are very small,and therefore very handy.
    Ice
  1. Capacity control
    By sparrow in forum Training
    Last Post: 18-01-2010, 07:49 PM
  2. Pool heat pump water side diagram
    By nike123 in forum Heat Pumps
    Last Post: 22-03-2009, 07:42 PM
  3. System sizing for heat and manual J
    By Larry2 in forum Heat Pumps
    Last Post: 25-06-2008, 10:58 AM
  4. frostles heat pump
  5. Heat pump pipe sizing - why bother?
    By alexdouglas1969 in forum Fundamentals
    Last Post: 03-04-2007, 09:14 PM
