    3,355
    Stal S56 / S57 compatability
    Does anybody have information on S56/S57 Stals .
    Would like to swap a S56 with S57 , hopefully with minimum fuss .
    Site is remote so hard size up without going there .
    The Netherlands
    54
    30
    Re: Stal S56 / S57 compatability
    Hello Ranger1,
    you probably know that the S56 is the older (let's say Mk1) model before the S57 came on the market. The capacity control position system is different but pretty easy to make it fit for the S57. The driveshaft and suction, discharge pipework are pretty much the same. I think the biggest problem is going to be the amount of oil used by the S57 compressor compared to the S56. The S56 has an old type 80 liter per minute oilpump compared to the 120 liter per minute S57 oilpump, and both have different oilpressure regulators. I'll try to find some more info which maybe is usefull for you.
    The Screwdoctor
    3,355
    Thanks Screwdoctor anything is a help .
    As far as oil pump , i think its had a remote oil pump installed . I should check its capacity .
    The Netherlands
    54
    30
    Ok Ranger1,
    I found some drawings and other info about the S54/S56, depends on what version you have over there to be more specific about the capacity control system, there are a few different setups. I think the latest models already have the same kind of oil control system as the S57 models. If I look at bearings, suction and discharge connection, footprint it is the same. If you have a question just ask.
    The Screwdoctor
  1. Stal Electronic 700
    By Gerben in forum Industrial Compressors
    Last Post: 07-10-2010, 06:33 AM
  2. Stal S26 manuals or advice please
    By riksly in forum Ye Old Wifes Tales
    Last Post: 20-02-2009, 08:44 AM
  3. Stal discharge check rattle mystery
    By Howeirdhughs in forum Trouble Shooting
    Last Post: 16-12-2008, 08:21 AM
  4. STAL SRM SCREW compressor
    By graeme ellis in forum Industrial Compressors
    Last Post: 15-03-2007, 02:01 AM
  5. Stal Problems
    By NH3LVR in forum Industrial Compressors
    Last Post: 16-09-2006, 11:08 AM
