Results 1 to 9 of 9
Thread: Precision AC
    iiternalfire's Avatar
    iiternalfire Guest
    Smile Precision AC
    What exactly is precision AC technology?
    How different is it from conventional window ACs?
    Where is it required?
    11,024
    Re: Precision AC
    I suppose that is what we would call "Close Control" systems.
    To provide close-control air conditioning you have to control both temperature and humidity levels.
    To accomplish this you often have to cool the air to reduce the humidity, then re-heat it so that the temperature is comfortable, then put more water vapour into the air to return the humidity back to acceptable levels.
    sourabhs's Avatar
    sourabhs Guest
    Re: Precision AC
    Precision cooling is all about sensible cooling. it provides about 95% sensible cooling. it is manily used for electronic cooling such as datacenter, telecom units,etc
    sourabhs's Avatar
    sourabhs Guest
    Re: Precision AC
    how can we calculate total cooling capacity & sensible cooling capacity of the unit. Is there any formula for calculating this?
    Volander's Avatar
    Volander Guest
    Re: Precision AC
    It depends of size of the unit, coil temperature, room temperature and relative humidity in the room. For standard conditions % hum(50% or 40%) and room temp (Db 24C) you may find in technical manual of any manufacturer of close control systems.
    Aug 2009
    Malaysia
    29
    Re: Precision AC
    normally close control units use EXV or TXV?
    Oct 2006
    Wexford
    47
    12
    Re: Precision AC
    normally CRAC's use TXV's
    EXV's are available as an option for most manufacturers
    dedi sunardi's Avatar
    dedi sunardi Guest
    Re: Precision AC
    hi everybody, precisian ac is provide for utility cooling not for human comfort, its maintain temperatur and humidity so precisian.depend on setting utility.
    Mar 2010
    UTAH
    Re: Precision AC
    Precision air-conditioning systems regulate temperature and humidity for sensitive technology.
    Its continuous operation reliably ensures the high availability of computer systems.
  1. Emergency Situation! Clivet(VR-CW) Precision AC!
    By sbkvelocity in forum Trouble Shooting
    Last Post: 25-04-2009, 02:26 PM
  2. Replies: 7
    Last Post: 28-11-2008, 04:53 PM
  3. Selection of Precision Air-Conditioning.
    By adeelquick in forum Air Conditioning
    Last Post: 11-11-2008, 04:19 AM
Tags for this Thread
