    ECOSPAN's Avatar
    ECOSPAN Guest
    Capacity Conversion Table
    Hello, I would like to check with you guys what is the proper method of calculating the capacity of an air-con unit. Please see below for the 2 different methods that I would like to check on, and the source that I obtained the calculations from.
    Source: Internet conversion table :
    1 Ton = 12000 BTU/h = 4.72 Horsepower = 3.52 kW
    Source: A few aircon servicing/repair companies
    1 Ton = 12000 BTU/h = 1.33 Horsepower = 0.99 kW
    Which is correct? Thanks
    11,025
    Re: Capacity Conversion Table
    The first one is correct.
    If you need a universal converter then please try this one...
    http://www.katmarsoftware.com/uconeer.htm
    Split Croatia
    6,151
    Second one is probably comparison from compressor refrigerant capacity to motor power consumed by compressor!
  1. How to increase pool heater capacity?
    By Drew in forum Commercial
    Last Post: 13-06-2009, 05:25 AM
  2. Sensible Heat Factor / capacity of Inverter split Systems at part load?
    By Greengrocer in forum Technical Speculations
    Last Post: 09-02-2009, 04:57 PM
  3. power conversion table
    By brianubaldo in forum Tools and Calculators
    Last Post: 09-09-2008, 05:40 AM
  4. R-407C and Coil Capacity
    By glabah in forum Refrigerants
    Last Post: 03-06-2006, 11:36 AM
  5. TEV capacity related to pressure drop
    By DaBit in forum CPU Overclockers
    Last Post: 06-12-2002, 05:11 PM
