Thread: Daikin AHU
    Apr 2004
    UK sunny North Devon
    59
    Angry Daikin AHU
    Hi can any one help on this one
    Daikin AHU sorry can’t remember the model number but the display has A B C on it, no fault codes on the display no warning lights on, metered out the thermister check ok, transmitting to and fro from AHU and cond’s but will not bring on the out side unit, set at 18c, air on 28c, turn the power on it run’s on down to its set point then will not cut back on, indoor pcb change still the same, customers not very happy and my service manager
    Help please
    Ps condensate pump not wired into the control circuit
    Jan 2003
    East Anglia
    1,175
    Re: Daikin AHU
    Hi Jan,
    Sorry doesn't ring any bells atached is he only list i have
    Try ringing Space air on 01483 504883.
    They have always been very helpful and spot time each time i have rang with a problem
    Raymond
    Attached Files Attached Files
    Oct 2001
    Nottingham UK
    5,086
    42
    Re: Daikin AHU
    We really do need to know the model type. Is the "emergency" switch in the correct position on the outdoor pcb? factory set is in the "white" area. Any changes to switches must be followed by a power reset.
    If you ring Space Air the first thing they will ask for is a model and serial number.
    I'm back on the Pale
    Apr 2004
    59
    Re: Daikin AHU
    Thanks for the replies, have been in contact with tech support did all the checks they suggested still no joy, model number on my paper work in my van will have to come back on that one thanks
    Sep 2003
    ISRAEL
    65
    4,114
    38
    Re: Daikin AHU
    Hi jan.
    Daikin is not sold in my country but, in all cases when an AHU started going funny, I've found a wire disconnected in the controls part.
    Have a check for a loos wire, who knows, it might be your day.
    Chemi
    Apr 2004
    59
    Re: Daikin AHU
    up date, went back with more info, AHU working perfect ?
  1. Daikin Refnet Position
    By puddleboy3 in forum Air Conditioning
    Last Post: 13-02-2009, 05:12 PM
  2. Daikin Analyzer
    By marc5180 in forum Fundamentals
    Last Post: 02-08-2008, 07:15 PM
  3. Daikin Controllers
    By airefresco in forum Air Conditioning
    Last Post: 15-05-2008, 08:08 AM
  4. Daikin VRV
    By nickthefridge in forum Air Conditioning
    Last Post: 14-10-2007, 01:42 PM
  5. !!big Daikin Problem!! Codes,u4,pj, And E0
    By airconengineer in forum Air Conditioning
    Last Post: 31-05-2007, 09:04 PM
